dmvpn hub has no nhrp info, spoke is stuck in NHRP
dgawaya1
My Dmvpn hub doesn't have any nhrp state, yet the spoke is stuch in NHRP
The hub config is here
The spoke config is here
I will appreciate your help
19 Replies 19
the tunnel is also under a customer vrf
@dgawaya1 the configuration you provided today does not have the "tunnel vrf <VRFNAME>" configured. Example:
interface tunnel 0
You only have "vrf forwarding <VRFNAME>".
dgawaya1
@Rob Ingram , @MHM Cisco World u guys are amazing. I got it working partly. The hub sides show up but the only one spoke is up. I will troubleshoot further. btw. I only added "tunnel vrf xxxx". I also know my routing might be a bit messy
////Hub
///Spoke
@dgawaya1 thats correct, I did say to configure that a couple of days ago.
You need to define the custom vrf, otherwise the router will use the global routing table to establish the tunnel to the peer. Glad it's working.
So messy' You nedd to clear routing issue.
It not only tunnel vrf
MHM
