GRE and Client VPN on 1800 on same interface
jhaggett
I'm trying to setup client VPN on an 1800 that already has a GRE VPN tunnel. Apparently, the router tells me that I cannot have an EazyVPN server as well as GRE on the same interface. Does anyone know a workaround to this? I'm simply just trying to allow remote client VPN to this router.
Thanks!!
spremkumar
Level 9
Level 9
hi
can you revert whether you are applying the crypto map under the tunnel interface ??
Also can you post the configset/error msgs which you are trying to do/which you are seeing over there ...
regds
Thanks for your response.. I do not have access to the configuration file right now, but, yes, the crypto map is created for the tunnel interface, and then bound to the outside interface.. When I try to create the EZVPN server (GUI), it pops up and says "You cannot create a VPN server on a GRE interface"
I'll try get more information when i'm back in front of the router next week.
Jamie
