HUB & SPOKE environment with ASA5512 as the HUB and ASA5505 as spoke.
Ken Mackay
I can't seem to get by the error's. Phase 1 completes, then the errors start, 7.0.0.2 recieved non-routine notify message no proposal choosen, connection terminated for peer 7.0.0.2 reason peer terminate remote proxy N/A local Proxy N/A, 7.0.0.2 removing peer from correlator table failed, no match, seesion being torn down reason user requested, group 7.0.0.2 automatic NAT detection status remote end is not behind NAT device, this end is not behind NAT device. The other end the ASA5512 I get IP 7.1.0.2 no valid authentication type found for the tunnel group, Remote end is not behind NAT device, the DAP records were selected for connection DfltAccessPolicy, Phase 1 completed, All IPSEC SA proposals found unacceptable, IP 7.1.0.2 QM FSM error, removing peer from correlator table failed no match, 7.1.0.2 session being torn down reason Phase 2 Mismatch, 7.1.0.2 session disconnected type IKEV1, recevied encrypted packet with no matchin SA dropping.
I have searched internet and found many results however as changes implemented I always end back at this point. Any HELP would be greatly appreciated. Lost two days in the LAB. I will post configs. This a test soon to go into production. Thanks
Ken
ASA1# sho run
: Saved
ASA Version 9.1(2)
hostname ASA1
domain-name TEST1.CA
enable password 8Ry2YjIyt7RRXU24 encrypted
names
interface GigabitEthernet0/0
 nameif Outside
 security-level 100
 ip address 7.0.0.2 255.255.255.0
interface GigabitEthernet0/1
 nameif AS1toR1
 security-level 50
 ip address 1.0.0.2 255.255.255.0
interface GigabitEthernet0/2
 nameif AS1toR2
 security-level 50
 ip address 3.0.0.2 255.255.255.0
interface GigabitEthernet0/3
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet0/4
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet0/5
 shutdown
 no nameif
 no security-level
 no ip address
interface Management0/0
 management-only
 nameif management
 security-level 0
ftp mode passive
dns domain-lookup Outside
dns domain-lookup AS1toR1
dns domain-lookup AS1toR2
dns domain-lookup management
dns server-group DefaultDNS
 name-server 201.201.201.201
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network obj-1.0.0.0
object network 2.0.0.0
 subnet 2.0.0.0 255.255.255.0
object network 6.0.0.0
 subnet 6.0.0.0 255.255.255.0
object network 7.1.0.0
 subnet 7.1.0.0 255.255.255.0
object network 8.0.0.0
 subnet 8.0.0.0 255.255.255.0
object network 9.0.0.0
 subnet 9.0.0.0 255.255.255.0
object-group network DM_INLINE_NETWORK_3
 network-object 1.0.0.0 255.255.255.0
 network-object 3.0.0.0 255.255.255.0
 network-object object 2.0.0.0
 network-object object 8.0.0.0
object-group network DM_INLINE_NETWORK_4
 network-object object 6.0.0.0
 network-object object 9.0.0.0
object-group network DM_INLINE_NETWORK_1
object-group network DM_INLINE_NETWORK_2
object-group network DM_INLINE_NETWORK_5
object-group network DM_INLINE_NETWORK_6
access-list HEADEND extended permit ip any any
access-list hq-to-vpnend extended permit ip object-group DM_INLINE_NETWORK_3 object-group DM_INLINE_NETWORK_4
access-list vpnend-to-hq extended permit ip object-group DM_INLINE_NETWORK_1 object-group DM_INLINE_NETWORK_2
access-list Outside_cryptomap_15 extended permit ip object-group DM_INLINE_NETWORK_5 object-group DM_INLINE_NETWORK_6
access-list Outside_access_in extended permit ip any any
access-list Outside_access_in extended permit icmp any4 any4
access-list AS1toR2_access_in extended permit icmp any4 any4
access-list AS1toR2_access_in extended permit ip any any
access-list AS1toR1_access_in extended permit ip any any
access-list AS1toR1_access_in extended permit icmp any4 any4
pager lines 24
logging enable
logging asdm informational
mtu Outside 1500
mtu AS1toR1 1500
mtu AS1toR2 1500
mtu management 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
access-group Outside_access_in in interface Outside
access-group AS1toR1_access_in in interface AS1toR1
access-group AS1toR2_access_in in interface AS1toR2
router ospf 1
 network 1.0.0.0 255.255.255.0 area 0
 network 3.0.0.0 255.255.255.0 area 0
 network 7.0.0.0 255.255.255.0 area 0
 log-adj-changes
route Outside 0.0.0.0 0.0.0.0 7.0.0.1 125
route Outside 6.0.0.0 255.255.255.0 7.0.0.1 125
route Outside 9.0.0.0 255.255.255.0 7.0.0.1 125
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
eou allow none
http server enable
http 192.168.1.2 255.255.255.255 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
sysopt connection preserve-vpn-flows
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA-TRANS esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-128-MD5-TRANS esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-192-SHA-TRANS esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-192-MD5-TRANS esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-256-SHA-TRANS esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-256-MD5-TRANS esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-3DES-SHA-TRANS esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-3DES-MD5-TRANS esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-DES-SHA-TRANS esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-DES-MD5-TRANS esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set MAP-VPN1 esp-3des esp-md5-hmac
crypto ipsec ikev2 ipsec-proposal AES256
 protocol esp encryption aes-256
 protocol esp integrity sha-1 md5
crypto ipsec ikev2 ipsec-proposal AES192
 protocol esp encryption aes-192
crypto ipsec ikev2 ipsec-proposal 3DES
 protocol esp encryption 3des
crypto ipsec ikev2 ipsec-proposal DES
 protocol esp encryption des
crypto ipsec security-association pmtu-aging infinite
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 5 match address Outside_cryptomap_15
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 5 set pfs
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 5 set ikev1 transform-set MAP-VPN1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 5 set reverse-route
crypto dynamic-map DYNMAP 10 set pfs
crypto dynamic-map DYNMAP 10 set ikev1 transform-set MAP-VPN1
crypto dynamic-map DYNMAP 10 set reverse-route
crypto map Outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map HQ2REMOTE 10 ipsec-isakmp dynamic DYNMAP
crypto map HQ2REMOTE interface Outside
crypto ca trustpool policy
crypto ikev1 enable Outside
crypto ikev1 policy 1
 authentication pre-share
 encryption 3des
 hash md5
 group 2
 lifetime 28800
telnet timeout 5
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
vpn-addr-assign local reuse-delay 30
vpn load-balancing
 interface lbpublic Outside
 interface lbprivate AS1toR1
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
 enable Outside
 no anyconnect-essentials
group-policy DfltGrpPolicy attributes
 wins-server value 10.10.10.10
 dns-server value 201.201.201.201
 vpn-idle-timeout none
 vpn-tunnel-protocol ikev1 l2tp-ipsec ssl-clientless
 split-tunnel-network-list value HEADEND
 default-domain value TEST1.CA
 webvpn
  activex-relay disable
tunnel-group DefaultL2LGroup ipsec-attributes
 ikev1 pre-shared-key *****
tunnel-group DefaultRAGroup general-attributes
 secondary-authentication-server-group LOCAL
 authorization-server-group LOCAL
 nat-assigned-to-public-ip Outside
tunnel-group DefaultRAGroup ipsec-attributes
 peer-id-validate nocheck
 ikev1 user-authentication none
tunnel-group DefaultWEBVPNGroup general-attributes
tunnel-group DefaultWEBVPNGroup ipsec-attributes
tunnel-group-map default-group DefaultL2LGroup
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
 profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly 24
  subscribe-to-alert-group configuration periodic monthly 24
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:022709234965ad8943628e790ed5ed1f
: end
ASA1#
ASA2# sho run
: Saved
ASA Version 8.2(5)
hostname ASA2
domain-name TEST2.CA
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
 switchport access vlan 14
interface Ethernet0/1
 switchport access vlan 24
interface Ethernet0/2
 shutdown
interface Ethernet0/3
 shutdown
interface Ethernet0/4
 shutdown
interface Ethernet0/5
 shutdown
interface Ethernet0/6
 shutdown
interface Ethernet0/7
 switchport access vlan 4
interface Vlan1
 no nameif
 no security-level
 no ip address
interface Vlan4
 nameif management.
 security-level 0
 ip address 192.168.1.101 255.255.255.0
 management-only
interface Vlan14
 nameif Outside
 security-level 100
 ip address dhcp setroute
interface Vlan24
 nameif Inside
 security-level 50
 ip address 6.0.0.2 255.255.255.0
ftp mode passive
dns domain-lookup management.
dns domain-lookup Inside
 network-object 2.0.0.0 255.255.255.0
 network-object 8.0.0.0 255.255.255.0
 network-object 6.0.0.0 255.255.255.0
 network-object 9.0.0.0 255.255.255.0
access-list REMOTEEND extended permit ip any any
access-list hq-to-vpnend extended permit ip object-group DM_INLINE_NETWORK_5 object-group DM_INLINE_NETWORK_6
access-list Outside_access_in extended permit icmp any any
access-list Inside_access_in extended permit ip any any
access-list Inside_access_in extended permit icmp any any
pager lines 24
logging enable
mtu management. 1500
mtu Outside 1500
mtu Inside 1500
no failover
arp timeout 14400
access-group Inside_access_in in interface Inside
router ospf 1
 network 6.0.0.0 255.255.255.0 area 0
 network 7.1.0.0 255.255.255.0 area 0
 log-adj-changes
route Outside 1.0.0.0 255.255.255.0 7.0.0.2 125
route Outside 2.0.0.0 255.255.255.0 7.0.0.2 125
route Outside 3.0.0.0 255.255.255.0 7.0.0.2 125
route Outside 8.0.0.0 255.255.255.0 7.0.0.2 125
 network-acl REMOTEEND
eou allow none
http server enable
http 0.0.0.0 0.0.0.0 management.
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set MAP-VPN1 esp-3des esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set MAP-VPN1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set reverse-route
crypto map HQ2REMOTE 15 match address vpnend-to-hq
crypto map HQ2REMOTE 15 set pfs
crypto map HQ2REMOTE 15 set connection-type originate-only
crypto map HQ2REMOTE 15 set peer 7.0.0.2
crypto map HQ2REMOTE 15 set transform-set MAP-VPN1
crypto map HQ2REMOTE 15 set security-association lifetime seconds 28800
crypto map HQ2REMOTE 15 set security-association lifetime kilobytes 4608000
crypto map HQ2REMOTE 15 set reverse-route
crypto map HQ2REMOTE 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto isakmp enable Outside
crypto isakmp policy 15
 encryption 3des
 hash md5
 group 2
 lifetime 28800
crypto isakmp ipsec-over-tcp port 10000
vpn-addr-assign local reuse-delay 5
telnet timeout 5
ssh timeout 5
console timeout 0
dhcp-client client-id interface Outside
ssl encryption 3des-sha1
webvpn
 enable Outside
 vpn-tunnel-protocol IPSec l2tp-ipsec svc webvpn
 split-tunnel-network-list value REMOTEEND
 default-domain value TEST2.CA
 smartcard-removal-disconnect disable
tunnel-group 7.0.0.2 type ipsec-l2l
tunnel-group 7.0.0.2 ipsec-attributes
tunnel-group-map default-group 7.0.0.2
 parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
call-home
 profile CiscoTAC-1
  no active
Cryptochecksum:0d04273f55e788e2a4ad4d025084d33d
: end
ASA2#
75 Replies 75
Ken
Sorry I didn't explain myself very well.
ASA1 and ASA2 are using a L2L VPN not a remote access VPN.
What I meant was apart from this tunnel do you have other remote access clients ?
Jon
Jon,
No. However in the future there would be additional L2L VPN's added.
Ken
Ken
Can you try adding this command to ASA1 -
"tunnel-group-map default-group DefaultL2LGroup"
then clear the tunnel on ASA1 and ASA2 if it is up, run the debug again and post it together with a "sh crypto ipsec sa".
Jon
Jon,
Added "tunnel-group-map default-group DefaultL2LGroup" to ASA1. Cleared tunnels and then executed show commands and debugs.
ASA1(config)#
ASA1(config)# clear ctypto ipsec sa
ERROR: % Invalid input detected at '^' marker.
ASA1(config)# clear crypto ipsec sa
ASA1(config)# sho crypto ipsec sa
interface: Outside
    Crypto map tag: DYNMAP, seq num: 10, local addr: 7.0.0.2
      local ident (addr/mask/prot/port): (7.0.0.2/255.255.255.255/0/0)
      remote ident (addr/mask/prot/port): (7.1.0.2/255.255.255.255/0/0)
      current_peer: 7.1.0.2, username: DefaultRAGroup
      dynamic allocated peer ip: 0.0.0.0
      #pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
      #pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
      #pkts compressed: 0, #pkts decompressed: 0
      #pkts not compressed: 0, #pkts comp failed: 0, #pkts decomp failed: 0
      #pre-frag successes: 0, #pre-frag failures: 0, #fragments created: 0
      #PMTUs sent: 0, #PMTUs rcvd: 0, #decapsulated frgs needing reassembly: 0
      #TFC rcvd: 0, #TFC sent: 0
      #Valid ICMP Errors rcvd: 0, #Invalid ICMP Errors rcvd: 0
      #send errors: 0, #recv errors: 0
      local crypto endpt.: 7.0.0.2/0, remote crypto endpt.: 7.1.0.2/0
      path mtu 1500, ipsec overhead 58(36), media mtu 1500
      PMTU time remaining (sec): 0, DF policy: copy-df
      ICMP error validation: disabled, TFC packets: disabled
      current outbound spi: 1B5621D4
      current inbound spi : F84FDD91
    inbound esp sas:
      spi: 0xF84FDD91 (4165983633)
         transform: esp-3des esp-md5-hmac no compression
         in use settings ={RA, Tunnel, IKEv1, }
         slot: 0, conn_id: 24576, crypto-map: DYNMAP
         sa timing: remaining key lifetime (sec): 28748
         IV size: 8 bytes
         replay detection support: Y
         Anti replay bitmap:
          0x00000000 0x00000001
    outbound esp sas:
      spi: 0x1B5621D4 (458629588)
         IV size: 8 bytes
         Anti replay bitmap:
ASA1(config)# debug crypto isakmp 127
ASA1(config)# Mar 03 09:54:07 [IKEv1]IP = 7.1.0.2, IKE_DECODE RECEIVED Message (msgid=74e2599b) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 80
Mar 03 09:54:07 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, processing hash payload
Mar 03 09:54:07 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, processing notify payload
Mar 03 09:54:07 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, Received keep-alive of type DPD R-U-THERE (seq number 0x41a918df)
Mar 03 09:54:07 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, Sending keep-alive of type DPD R-U-THERE-ACK (seq number 0x41a918df)
Mar 03 09:54:07 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, constructing blank hash payload
Mar 03 09:54:07 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, constructing qm hash payload
Mar 03 09:54:07 [IKEv1]IP = 7.1.0.2, IKE_DECODE SENDING Message (msgid=cbd9f5b8) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 80
Mar 03 09:54:17 [IKEv1]IP = 7.1.0.2, IKE_DECODE RECEIVED Message (msgid=88e3af5b) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 80
Mar 03 09:54:17 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, processing hash payload
Mar 03 09:54:17 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, processing notify payload
Mar 03 09:54:17 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, Received keep-alive of type DPD R-U-THERE (seq number 0x41a918e0)
Mar 03 09:54:17 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, Sending keep-alive of type DPD R-U-THERE-ACK (seq number 0x41a918e0)
Mar 03 09:54:17 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, constructing blank hash payload
Mar 03 09:54:17 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, constructing qm hash payload
Mar 03 09:54:17 [IKEv1]IP = 7.1.0.2, IKE_DECODE SENDING Message (msgid=babaf47) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 80
Mar 03 09:54:27 [IKEv1]IP = 7.1.0.2, IKE_DECODE RECEIVED Message (msgid=9823cd38) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 80
Mar 03 09:54:27 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, processing hash payload
Mar 03 09:54:27 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, processing notify payload
Mar 03 09:54:27 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, Received keep-alive of type DPD R-U-THERE (seq number 0x41a918e1)
Mar 03 09:54:27 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, Sending keep-alive of type DPD R-U-THERE-ACK (seq number 0x41a918e1)
Mar 03 09:54:27 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, constructing blank hash payload
Mar 03 09:54:27 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, constructing qm hash payload
Mar 03 09:54:27 [IKEv1]IP = 7.1.0.2, IKE_DECODE SENDING Message (msgid=4185721d) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 80
Mar 03 09:54:37 [IKEv1]IP = 7.1.0.2, IKE_DECODE RECEIVED Message (msgid=cd6e15a5) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 80
Mar 03 09:54:37 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, processing hash payload
Mar 03 09:54:37 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, processing notify payload
Mar 03 09:54:37 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, Received keep-alive of type DPD R-U-THERE (seq number 0x41a918e2)
Mar 03 09:54:37 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, Sending keep-alive of type DPD R-U-THERE-ACK (seq number 0x41a918e2)
Mar 03 09:54:37 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, constructing blank hash payload
Mar 03 09:54:37 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, constructing qm hash payload
Mar 03 09:54:37 [IKEv1]IP = 7.1.0.2, IKE_DECODE SENDING Message (msgid=b5335a76) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 80
Mar 03 09:54:47 [IKEv1]IP = 7.1.0.2, IKE_DECODE RECEIVED Message (msgid=782fc0a0) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 80
Mar 03 09:54:47 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, processing hash payload
Mar 03 09:54:47 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, processing notify payload
Mar 03 09:54:47 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, Received keep-alive of type DPD R-U-THERE (seq number 0x41a918e3)
Mar 03 09:54:47 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, Sending keep-alive of type DPD R-U-THERE-ACK (seq number 0x41a918e3)
Mar 03 09:54:47 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, constructing blank hash payload
Mar 03 09:54:47 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, constructing qm hash payload
Mar 03 09:54:47 [IKEv1]IP = 7.1.0.2, IKE_DECODE SENDING Message (msgid=14b6c234) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 80
Mar 03 09:54:57 [IKEv1]IP = 7.1.0.2, IKE_DECODE RECEIVED Message (msgid=df4be4f2) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 80
Mar 03 09:54:57 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, processing hash payload
Mar 03 09:54:57 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, processing notify payload
Mar 03 09:54:57 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, Received keep-alive of type DPD R-U-THERE (seq number 0x41a918e4)
Mar 03 09:54:57 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, Sending keep-alive of type DPD R-U-THERE-ACK (seq number 0x41a918e4)
Mar 03 09:54:57 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, constructing blank hash payload
Mar 03 09:54:57 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, constructing qm hash payload
Mar 03 09:54:57 [IKEv1]IP = 7.1.0.2, IKE_DECODE SENDING Message (msgid=f826b39) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 80
Mar 03 09:55:07 [IKEv1]IP = 7.1.0.2, IKE_DECODE RECEIVED Message (msgid=adb5a1df) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 80
Mar 03 09:55:07 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, processing hash payload
Mar 03 09:55:07 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, processing notify payload
Mar 03 09:55:07 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, Received keep-alive of type DPD R-U-THERE (seq number 0x41a918e5)
Mar 03 09:55:07 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, Sending keep-alive of type DPD R-U-THERE-ACK (seq number 0x41a918e5)
Mar 03 09:55:07 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, constructing blank hash payload
Mar 03 09:55:07 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, constructing qm hash payload
Mar 03 09:55:07 [IKEv1]IP = 7.1.0.2, IKE_DECODE SENDING Message (msgid=575f809b) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 80
ASA1(config)# undeMar 03 09:55:17 [IKEv1]IP = 7.1.0.2, IKE_DECODE RECEIVED Message (msgid=a0417874) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 80
Mar 03 09:55:17 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, processing hash payload
Mar 03 09:55:17 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, processing notify payload
Mar 03 09:55:17 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, Received keep-alive of type DPD R-U-THERE (seq number 0x41a918e6)
Mar 03 09:55:17 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, Sending keep-alive of type DPD R-U-THERE-ACK (seq number 0x41a918e6)
Mar 03 09:55:17 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, constructing blank hash payload
Mar 03 09:55:17 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, constructing qm hash payload
Mar 03 09:55:17 [IKEv1]IP = 7.1.0.2, IKE_DECODE SENDING Message (msgid=1509939) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 80
bug all
ASA1(config)# debug crypto ipsec 127
ASA1(config)#
ASA1(config)#
ASA2(config)# clear crypto ipsec sa
ASA2(config)#
ASA2(config)#
ASA2(config)#
ASA2(config)#
ASA2(config)#
ASA2(config)# sho crypto ipsec sa
interface: Outside
    Crypto map tag: HQ2REMOTE, seq num: 15, local addr: 7.1.0.2
      access-list OO_temp_HQ2REMOTE15 extended permit ip host 7.1.0.2 host 7.0.0.2
      local ident (addr/mask/prot/port): (7.1.0.2/255.255.255.255/0/0)
      remote ident (addr/mask/prot/port): (7.0.0.2/255.255.255.255/0/0)
      current_peer: 7.0.0.2
      local crypto endpt.: 7.1.0.2, remote crypto endpt.: 7.0.0.2
      path mtu 1500, ipsec overhead 58, media mtu 1500
      current outbound spi: C9B808DB
      current inbound spi : 5C226B32
    inbound esp sas:
      spi: 0x5C226B32 (1545759538)
         in use settings ={L2L, Tunnel, }
         slot: 0, conn_id: 20480, crypto-map: HQ2REMOTE
         sa timing: remaining key lifetime (kB/sec): (4374000/28752)
         IV size: 8 bytes
         Anti replay bitmap:
    outbound esp sas:
      spi: 0xC9B808DB (3384281307)
         IV size: 8 bytes
         Anti replay bitmap:
ASA2(config)# debug crypto isakmp 127
ASA2(config)# Mar 03 05:26:05 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, Sending keep-alive of type DPD R-U-THERE (seq number 0x1b082f)
Mar 03 05:26:05 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, constructing blank hash payload
Mar 03 05:26:05 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, constructing qm hash payload
Mar 03 05:26:05 [IKEv1]: IP = 7.0.0.2, IKE_DECODE SENDING Message (msgid=2b5e0275) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 80
Mar 03 05:26:05 [IKEv1]: IP = 7.0.0.2, IKE_DECODE RECEIVED Message (msgid=74ec6398) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 80
Mar 03 05:26:05 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, processing hash payload
Mar 03 05:26:05 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, processing notify payload
Mar 03 05:26:05 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, Received keep-alive of type DPD R-U-THERE-ACK (seq number 0x1b082f)
Mar 03 05:26:15 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, Sending keep-alive of type DPD R-U-THERE (seq number 0x1b0830)
Mar 03 05:26:15 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, constructing blank hash payload
Mar 03 05:26:15 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, constructing qm hash payload
Mar 03 05:26:15 [IKEv1]: IP = 7.0.0.2, IKE_DECODE SENDING Message (msgid=c59e2ede) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 80
Mar 03 05:26:15 [IKEv1]: IP = 7.0.0.2, IKE_DECODE RECEIVED Message (msgid=c3d181f4) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 80
Mar 03 05:26:15 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, processing hash payload
Mar 03 05:26:15 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, processing notify payload
Mar 03 05:26:15 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, Received keep-alive of type DPD R-U-THERE-ACK (seq number 0x1b0830)
Mar 03 05:26:25 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, Sending keep-alive of type DPD R-U-THERE (seq number 0x1b0831)
Mar 03 05:26:25 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, constructing blank hash payload
Mar 03 05:26:25 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, constructing qm hash payload
Mar 03 05:26:25 [IKEv1]: IP = 7.0.0.2, IKE_DECODE SENDING Message (msgid=e2fddb2b) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 80
Mar 03 05:26:25 [IKEv1]: IP = 7.0.0.2, IKE_DECODE RECEIVED Message (msgid=db0700b) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 80
Mar 03 05:26:25 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, processing hash payload
Mar 03 05:26:25 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, processing notify payload
Mar 03 05:26:25 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, Received keep-alive of type DPD R-U-THERE-ACK (seq number 0x1b0831)
Mar 03 05:26:35 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, Sending keep-alive of type DPD R-U-THERE (seq number 0x1b0832)
Mar 03 05:26:35 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, constructing blank hash payload
Mar 03 05:26:35 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, constructing qm hash payload
Mar 03 05:26:35 [IKEv1]: IP = 7.0.0.2, IKE_DECODE SENDING Message (msgid=7d4a4584) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 80
Mar 03 05:26:35 [IKEv1]: IP = 7.0.0.2, IKE_DECODE RECEIVED Message (msgid=65dda1f0) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 80
Mar 03 05:26:35 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, processing hash payload
Mar 03 05:26:35 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, processing notify payload
Mar 03 05:26:35 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, Received keep-alive of type DPD R-U-THERE-ACK (seq number 0x1b0832)
Mar 03 05:26:45 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, Sending keep-alive of type DPD R-U-THERE (seq number 0x1b0833)
Mar 03 05:26:45 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, constructing blank hash payload
Mar 03 05:26:45 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, constructing qm hash payload
Mar 03 05:26:45 [IKEv1]: IP = 7.0.0.2, IKE_DECODE SENDING Message (msgid=6740b448) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 80
Mar 03 05:26:45 [IKEv1]: IP = 7.0.0.2, IKE_DECODE RECEIVED Message (msgid=47d22fa9) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 80
Mar 03 05:26:45 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, processing hash payload
Mar 03 05:26:45 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, processing notify payload
Mar 03 05:26:45 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, Received keep-alive of type DPD R-U-THERE-ACK (seq number 0x1b0833)
ASA2(config)# undebug alMar 03 05:26:55 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, Sending keep-alive of type DPD R-U-THERE (seq number 0x1b0834)
Mar 03 05:26:55 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, constructing blank hash payload
Mar 03 05:26:55 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, constructing qm hash payload
Mar 03 05:26:55 [IKEv1]: IP = 7.0.0.2, IKE_DECODE SENDING Message (msgid=e1c13ecd) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 80
Mar 03 05:26:55 [IKEv1]: IP = 7.0.0.2, IKE_DECODE RECEIVED Message (msgid=d551dbf9) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 80
Mar 03 05:26:55 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, processing hash payload
Mar 03 05:26:55 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, processing notify payload
Mar 03 05:26:55 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, Received keep-alive of type DPD R-U-THERE-ACK (seq number 0x1b0834)
l
ASA2(config)# debug crypto ipsec 127
ASA2(config)#
ASA2(config)#
ASA2(config)#
ASA2(config)# undebug all
Ken
Ken
When you do the "clear crypto ipsec sa" you need to do it from enable mode not config mode.
I don't think you cleared them.
So can you clear them and before you try and test with ping make sure the "sh crypto ipsec sa" shows nothing.
Also and just as importantly can you also from enable mode do a "clear crypto isakmp sa".
We need to make sure nothing has been negotiated before we try and start a new tunnel.
Sorry it is taking so long to do but I think we are just going to keep at it until we get it to use the right group.
Jon
Jon,
Completed as explained. Appreciate your help I want to work until we get right as well.
ASA1# clear crypto ipsec sa
ASA1# IPSEC: Removing outbound VPN filter DAP-ip-user-A0F3D00B
IPSEC: Deleted outbound encrypt rule, SPI 0x40FF8382
    Rule ID: 0x00007fff9f76ddb0
IPSEC: Deleted outbound permit rule, SPI 0x40FF8382
    Rule ID: 0x00007fffa0000180
IPSEC: Deleted outbound VPN context, SPI 0x40FF8382
    VPN handle: 0x000000000004a6fc
IPSEC: Removing inbound VPN filter DAP-ip-user-A0F3D00B
IPSEC: Deleted inbound decrypt rule, SPI 0x6AA49192
    Rule ID: 0x00007fff9f764700
IPSEC: Deleted inbound permit rule, SPI 0x6AA49192
    Rule ID: 0x00007fffa0001050
IPSEC: Deleted inbound tunnel flow rule, SPI 0x6AA49192
    Rule ID: 0x00007fff9e5e7de0
IPSEC: Deleted inbound VPN context, SPI 0x6AA49192
    VPN handle: 0x000000000004c234
IPSEC: New embryonic SA created @ 0x00007fff9e6219f0,
    SCB: 0x9833CB70,
    Direction: inbound
    SPI      : 0xD062B565
    Session ID: 0x00014000
    VPIF num  : 0x00000002
    Tunnel type: ra
    Protocol   : esp
    Lifetime   : 240 seconds
IPSEC: New embryonic SA created @ 0x00007fffa0000b90,
    SCB: 0x9E6D6040,
    Direction: outbound
    SPI      : 0x6D2C93BF
    Tunnel type: ra
    Protocol   : esp
IPSEC: Completed host OBSA update, SPI 0x6D2C93BF
IPSEC: Creating outbound VPN context, SPI 0x6D2C93BF
    Flags: 0x00000085
    SA   : 0x00007fffa0000b90
    SPI  : 0x6D2C93BF
    MTU  : 1500 bytes
    VCID : 0x00000000
    Peer : 0x00000000
    SCB  : 0x0FD608BB
    Channel: 0x00007fff9830d9c0
IPSEC: Completed outbound VPN context, SPI 0x6D2C93BF
    VPN handle: 0x000000000004ef54
IPSEC: New outbound encrypt rule, SPI 0x6D2C93BF
    Src addr: 7.0.0.2
    Src mask: 255.255.255.255
    Dst addr: 7.1.0.2
    Dst mask: 255.255.255.255
    Src ports
      Upper: 0
      Lower: 0
      Op   : ignore
    Dst ports
      Upper: 0
      Lower: 0
      Op   : ignore
    Protocol: 0
    Use protocol: false
    SPI: 0x00000000
    Use SPI: false
IPSEC: Completed outbound encrypt rule, SPI 0x6D2C93BF
    Rule ID: 0x00007fff9e64c520
IPSEC: New outbound permit rule, SPI 0x6D2C93BF
    Src addr: 7.0.0.2
    Dst addr: 7.1.0.2
    Src ports
      Upper: 0
      Lower: 0
      Op   : ignore
    Dst ports
      Upper: 0
      Lower: 0
      Op   : ignore
    Protocol: 50
    Use protocol: true
    SPI: 0x6D2C93BF
    Use SPI: true
IPSEC: Completed outbound permit rule, SPI 0x6D2C93BF
    Rule ID: 0x00007fff9ee05110
IPSEC: Installed outbound VPN filter DAP-ip-user-A0F3D00B
IPSEC: Completed outbound user rule, SPI 0x6D2C93BF
    Rule ID: 0x0000000000000005
IPSEC: Completed host IBSA update, SPI 0xD062B565
IPSEC: Creating inbound VPN context, SPI 0xD062B565
    Flags: 0x00000086
    SA   : 0x00007fff9e6219f0
    SPI  : 0xD062B565
    MTU  : 0 bytes
    VCID : 0x00000000
    Peer : 0x0004EF54
    SCB  : 0x0FD5D5E5
IPSEC: Completed inbound VPN context, SPI 0xD062B565
    VPN handle: 0x0000000000051fac
IPSEC: Updating outbound VPN context 0x0004EF54, SPI 0x6D2C93BF
    Flags: 0x00000085
    SPI  : 0x6D2C93BF
    MTU  : 1500 bytes
    VCID : 0x00000000
    Peer : 0x00051FAC
    SCB  : 0x0FD608BB
IPSEC: Completed outbound inner rule, SPI 0x6D2C93BF
IPSEC: Completed outbound outer SPD rule, SPI 0x6D2C93BF
IPSEC: New inbound tunnel flow rule, SPI 0xD062B565
    Src addr: 7.1.0.2
    Dst addr: 7.0.0.2
    Src ports
      Upper: 0
      Lower: 0
      Op   : ignore
    Dst ports
      Upper: 0
      Lower: 0
      Op   : ignore
    Protocol: 0
    Use protocol: false
    SPI: 0x00000000
    Use SPI: false
IPSEC: Completed inbound tunnel flow rule, SPI 0xD062B565
IPSEC: New inbound decrypt rule, SPI 0xD062B565
    Src addr: 7.1.0.2
    Dst addr: 7.0.0.2
    Src ports
      Upper: 0
      Lower: 0
      Op   : ignore
    Dst ports
      Upper: 0
      Lower: 0
      Op   : ignore
    Protocol: 50
    Use protocol: true
    SPI: 0xD062B565
    Use SPI: true
                                                              IPSEC: Completed inbound decrypt rule, SPI 0xD062B565
    Rule ID: 0x00007fff9f979b80
IPSEC: New inbound permit rule, SPI 0xD062B565
    Src addr: 7.1.0.2
    Dst addr: 7.0.0.2
    Src ports
      Upper: 0
      Lower: 0
      Op   : ignore
    Dst ports
      Upper: 0
      Lower: 0
      Op   : ignore
    Protocol: 50
    Use protocol: true
    SPI: 0xD062B565
    Use SPI: true
IPSEC: Completed inbound permit rule, SPI 0xD062B565
IPSEC: Installed inbound VPN filter DAP-ip-user-A0F3D00B
IPSEC: Completed inbound user rule, SPI 0xD062B565
    Rule ID: 0x0000000000000005        $
ASA1# clear crypto isakmp sa
IPSEC: Deleted outbound encrypt rule, SPI 0x6D2C93BF
IPSEC: Deleted outbound permit rule, SPI 0x6D2C93BF
IPSEC: Deleted outbound VPN context, SPI 0x6D2C93BF
IPSEC: Deleted inbound decrypt rule, SPI 0xD062B565
IPSEC: Deleted inbound permit rule, SPI 0xD062B565
IPSEC: Deleted inbound tunnel flow rule, SPI 0xD062B565
IPSEC: Deleted inbound VPN context, SPI 0xD062B565
    SCB: 0x9E621780,
    Direction: inbound
    SPI      : 0x08658EF4
    Session ID: 0x00015000
    Tunnel type: ra
    Protocol   : esp
    SCB: 0x9E64CF50,
    Direction: outbound
    SPI      : 0x2C16D91C
    Tunnel type: ra
    Protocol   : esp
IPSEC: Completed host OBSA update, SPI 0x2C16D91C
IPSEC: Creating outbound VPN context, SPI 0x2C16D91C
    Flags: 0x00000085
    SPI  : 0x2C16D91C
    MTU  : 1500 bytes
    VCID : 0x00000000
    Peer : 0x00000000
    SCB  : 0x0FDBA599
IPSEC: Completed outbound VPN context, SPI 0x2C16D91C
    VPN handle: 0x0000000000052b6c
IPSEC: New outbound encrypt rule, SPI 0x2C16D91C
    Src addr: 7.0.0.2
    Dst addr: 7.1.0.2
    Src ports
      Upper: 0
      Lower: 0
      Op   : ignore
    Dst ports
      Upper: 0
      Lower: 0
      Op   : ignore
    Protocol: 0
    Use protocol: false
    SPI: 0x00000000
    Use SPI: false
IPSEC: Completed outbound encrypt rule, SPI 0x2C16D91C
    Rule ID: 0x00007fff9833cc00
IPSEC: New outbound permit rule, SPI 0x2C16D91C
    Src addr: 7.0.0.2
    Dst addr: 7.1.0.2
    Src ports
      Upper: 0
      Lower: 0
      Op   : ignore
    Dst ports
      Upper: 0
      Lower: 0
      Op   : ignore
    Protocol: 50
    Use protocol: true
    SPI: 0x2C16D91C
    Use SPI: true
IPSEC: Completed outbound permit rule, SPI 0x2C16D91C
IPSEC: Completed outbound user rule, SPI 0x2C16D91C
IPSEC: Completed host IBSA update, SPI 0x08658EF4
IPSEC: Creating inbound VPN context, SPI 0x08658EF4
    Flags: 0x00000086
    SPI  : 0x08658EF4
    MTU  : 0 bytes
    VCID : 0x00000000
    Peer : 0x00052B6C
    SCB  : 0x0FDB6EE1
IPSEC: Completed inbound VPN context, SPI 0x08658EF4
    VPN handle: 0x00000000000545e4
IPSEC: Updating outbound VPN context 0x00052B6C, SPI 0x2C16D91C
    Flags: 0x00000085
    SPI  : 0x2C16D91C
    MTU  : 1500 bytes
    VCID : 0x00000000
    Peer : 0x000545E4
    SCB  : 0x0FDBA599
IPSEC: Completed outbound inner rule, SPI 0x2C16D91C
IPSEC: Completed outbound outer SPD rule, SPI 0x2C16D91C
IPSEC: New inbound tunnel flow rule, SPI 0x08658EF4
    Src addr: 7.1.0.2
    Dst addr: 7.0.0.2
    Src ports
      Upper: 0
      Lower: 0
      Op   : ignore
    Dst ports
      Upper: 0
      Lower: 0
      Op   : ignore
    Protocol: 0
    Use protocol: false
    SPI: 0x00000000
    Use SPI: false
IPSEC: Completed inbound tunnel flow rule, SPI 0x08658EF4
    Rule ID: 0x00007fff98ba2150
IPSEC: New inbound decrypt rule, SPI 0x08658EF4
    Src addr: 7.1.0.2
    Dst addr: 7.0.0.2
    Src ports
      Upper: 0
      Lower: 0
      Op   : ignore
    Dst ports
      Upper: 0
      Lower: 0
      Op   : ignore
    Protocol: 50
    Use protocol: true
    SPI: 0x08658EF4
    Use SPI: true
 IPSEC: Completed inbound decrypt rule, SPI 0x08658EF4
    Rule ID: 0x00007fff9f8671a0
IPSEC: New inbound permit rule, SPI 0x08658EF4
    Src addr: 7.1.0.2
    Dst addr: 7.0.0.2
    Src ports
      Upper: 0
      Lower: 0
      Op   : ignore
    Dst ports
      Upper: 0
      Lower: 0
      Op   : ignore
    Protocol: 50
    Use protocol: true
    SPI: 0x08658EF4
    Use SPI: true
IPSEC: Completed inbound permit rule, SPI 0x08658EF4
    Rule ID: 0x00007fff9e5fef00
IPSEC: Completed inbound user rule, SPI 0x08658EF4
ASA1# sho crypto ipsec sa
interface: Outside
      current outbound spi: 2C16D91C
      current inbound spi : 08658EF4
    inbound esp sas:
      spi: 0x08658EF4 (140873460)
         slot: 0, conn_id: 86016, crypto-map: DYNMAP
         sa timing: remaining key lifetime (sec): 28786
         IV size: 8 bytes
         Anti replay bitmap:
    outbound esp sas:
      spi: 0x2C16D91C (739694876)
         IV size: 8 bytes
         Anti replay bitmap:
ASA1#
Ken
Ken
I need to have a look at the docs because i cannot understand what is happening here.
Can you do this for me -
1) remove any key from the DefaultRAGroup
2) remove this line from ASA2 -
3) power down both devices and start them up again
then try and ping again and do a "sh crypto ipsec sa" and post the results.
I will have a look at the docs to see if i can work out why it is not using the DefaultL2LGroup.
If there is nothing obvious then we can start removing things from the configurations to make it as simple as possible.
If we still can't get it to work then we can post another question specifically about it using the wrong group.
Jon
Jon,
Removed key from DefaultRAGroup. Also removed crypto isakmp ipsec-over-tcp port 10000 on ASA2. Then powered down both devices. I'm running a constant ping from 9.0.0.2 over to 8.0.0.1 I'm not to worried about that at the moment because like yourself I'm more concerned why where not using the DefaultL2LGroup. However for the ping accross I'm getting "deny inbound icmp SRC Inside:9.0.0.2 dst Outside:8.0.0.1(type8 code 0) error.
interface: Outside
      current outbound spi: 2797D44C
      current inbound spi : 0B3739E6
    inbound esp sas:
      spi: 0x0B3739E6 (188168678)
         in use settings ={L2L, Tunnel, IKEv1, }
         slot: 0, conn_id: 4096, crypto-map: DYNMAP
         sa timing: remaining key lifetime (kB/sec): (3915000/28754)
         IV size: 8 bytes
         Anti replay bitmap:
    outbound esp sas:
      spi: 0x2797D44C (664261708)
         IV size: 8 bytes
         Anti replay bitmap:
ASA1#
ASA2# sho crypto ipsec sa
interface: Outside
      current outbound spi: 0B3739E6
      current inbound spi : 2797D44C
    inbound esp sas:
         slot: 0, conn_id: 4096, crypto-map: HQ2REMOTE
         sa timing: remaining key lifetime (kB/sec): (4374000/28539)
         IV size: 8 bytes
         Anti replay bitmap:
    outbound esp sas:
         IV size: 8 bytes
         Anti replay bitmap:
ASA2#
Ken
Ken
Can you post your current configs from both ASAs.
Jon
Jon,
Current configs.
ASA1# sho run
: Saved
ASA Version 9.1(2)
hostname ASA1
names
 nameif Outside
 security-level 100
 nameif AS1toR1
 security-level 50
 nameif AS1toR2
 security-level 50
 shutdown
 no nameif
 no security-level
 no ip address
 shutdown
 no nameif
 no security-level
 no ip address
 shutdown
 no nameif
 no security-level
 no ip address
 management-only
 nameif management
 security-level 0
ftp mode passive
access-list Outside_access_out extended permit icmp any4 any4
access-list Outside_access_out extended permit ip any any
pager lines 24
logging enable
mtu Outside 1500
mtu AS1toR1 1500
mtu AS1toR2 1500
mtu management 1500
no failover
arp timeout 14400
router ospf 1
 log-adj-changes
 network-acl Outside_cryptomap_15
eou allow none
http server enable
crypto isakmp identity address
 encryption 3des
 hash md5
 group 2
 lifetime 28800
telnet timeout 5
ssh timeout 5
console timeout 0
vpn load-balancing
webvpn
 enable Outside
 vpn-tunnel-protocol ikev1 ssl-clientless
 webvpn
 parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
call-home
 profile CiscoTAC-1
  no active
Cryptochecksum:cd6c70a3b82bc2249ff9778ae7722808
: end
ASA1#
ASA2#
ASA2#
ASA2#
ASA2# sho run
: Saved
ASA Version 8.2(5)
hostname ASA2
names
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
interface Vlan1
 no nameif
 no security-level
 no ip address
interface Vlan4
 nameif management.
 security-level 0
 management-only
interface Vlan14
 nameif Outside
 security-level 100
interface Vlan24
 nameif Inside
 security-level 50
ftp mode passive
access-list Outside_access_out extended permit icmp any any
pager lines 24
logging enable
mtu Outside 1500
mtu Inside 1500
no failover
arp timeout 14400
router ospf 1
 log-adj-changes
 network-acl vpnend-to-hq
eou allow none
http server enable
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set peer 7.0.0.2
 encryption 3des
 hash md5
 group 2
 lifetime 28800
telnet timeout 5
ssh timeout 5
console timeout 0
webvpn
 enable Outside
 parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
call-home
 profile CiscoTAC-1
  no active
Cryptochecksum:461b26d0d685068d8002b243da17a201
: end
ASA2#
Ken
Ken
You are missing the crypto map acl in ASA1 again eg. -
"crypto dynamic-map DYNMAP 10 match address <acl name>"
probably got lost when you reloaded the ASA and perhaps you didn't save the configuration.
Can you put it back in, clear the tunnel and make sure they are cleared then try again.
And then post a "sh crypto ipsec sa" again.
Jon
Jon,
Re-created the ACL <hq-to-vpnend> then applied the crypto and cleared ipsec and isakmp. There are no ipsec sas. The tunnel isn't up.
Ken
Ken
Do you mean the tunnel isn't coming up ?
If so can you post "debug crypto isakmp 127"
Jon
Jon,
Getting same errors as when we first started. Access list mismatch skipping dynamic map DYNMAP.
Mar 03 13:18:47 [IKEv1]IP = 7.1.0.2, IKE_DECODE RECEIVED Message (msgid=0) with payloads : HDR + KE (4) + NONCE (10) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NAT-D (20) + NAT-D (20) + NONE (0) total length : 296
Mar 03 13:18:47 [IKEv1 DEBUG]IP = 7.1.0.2, processing ke payload
Mar 03 13:18:47 [IKEv1 DEBUG]IP = 7.1.0.2, processing ISA_KE payload
Mar 03 13:18:47 [IKEv1 DEBUG]IP = 7.1.0.2, processing nonce payload
Mar 03 13:18:47 [IKEv1 DEBUG]IP = 7.1.0.2, processing VID payload
Mar 03 13:18:47 [IKEv1 DEBUG]IP = 7.1.0.2, Received Cisco Unity client VID
Mar 03 13:18:47 [IKEv1 DEBUG]IP = 7.1.0.2, Received xauth V6 VID
Mar 03 13:18:47 [IKEv1 DEBUG]IP = 7.1.0.2, Processing VPN3000/ASA spoofing IOS Vendor ID payload (version: 1.0.0, capabilities: 20000001)
Mar 03 13:18:47 [IKEv1 DEBUG]IP = 7.1.0.2, Received Altiga/Cisco VPN3000/Cisco ASA GW VID
Mar 03 13:18:47 [IKEv1 DEBUG]IP = 7.1.0.2, processing NAT-Discovery payload
Mar 03 13:18:47 [IKEv1 DEBUG]IP = 7.1.0.2, computing NAT Discovery hash
Mar 03 13:18:47 [IKEv1 DEBUG]IP = 7.1.0.2, constructing ke payload
Mar 03 13:18:47 [IKEv1 DEBUG]IP = 7.1.0.2, constructing nonce payload
Mar 03 13:18:47 [IKEv1 DEBUG]IP = 7.1.0.2, constructing Cisco Unity VID payload
Mar 03 13:18:47 [IKEv1 DEBUG]IP = 7.1.0.2, constructing xauth V6 VID payload
Mar 03 13:18:47 [IKEv1 DEBUG]IP = 7.1.0.2, Send IOS VID
Mar 03 13:18:47 [IKEv1 DEBUG]IP = 7.1.0.2, Constructing ASA spoofing IOS Vendor ID payload (version: 1.0.0, capabilities: 20000001)
Mar 03 13:18:47 [IKEv1 DEBUG]IP = 7.1.0.2, constructing VID payload
Mar 03 13:18:47 [IKEv1 DEBUG]IP = 7.1.0.2, Send Altiga/Cisco VPN3000/Cisco ASA GW VID
Mar 03 13:18:47 [IKEv1 DEBUG]IP = 7.1.0.2, constructing NAT-Discovery payload
Mar 03 13:18:47 [IKEv1]IP = 7.1.0.2, Connection landed on tunnel_group DefaultL2LGroup
Mar 03 13:18:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, Generating keys for Responder...
ASA1# Mar 03 13:18:47 [IKEv1]IP = 7.1.0.2, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + KE (4) + NONCE (10) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NAT-D (20) + NAT-D (20) + NONE (0) total length : 296
Mar 03 13:18:47 [IKEv1]IP = 7.1.0.2, IKE_DECODE RECEIVED Message (msgid=0) with payloads : HDR + ID (5) + HASH (8) + IOS KEEPALIVE (128) + VENDOR (13) + NONE (0) total length : 92
Mar 03 13:18:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, processing ID payload
Mar 03 13:18:47 [IKEv1 DECODE]Group = DefaultL2LGroup, IP = 7.1.0.2, ID_IPV4_ADDR ID received
7.1.0.2
Mar 03 13:18:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, processing hash payload
Mar 03 13:18:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, Computing hash for ISAKMP
Mar 03 13:18:47 [IKEv1 DEBUG]IP = 7.1.0.2, Processing IOS keep alive payload: proposal=32767/32767 sec.
Mar 03 13:18:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, processing VID payload
Mar 03 13:18:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, Received DPD VID
Mar 03 13:18:47 [IKEv1]Group = DefaultL2LGroup, IP = 7.1.0.2, Automatic NAT Detection Status:     Remote end is NOT behind a NAT device     This   end is NOT behind a NAT device
Mar 03 13:18:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, constructing ID payload
Mar 03 13:18:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, constructing hash payload
Mar 03 13:18:47 [IKEv1 DEBUG]IP = 7.1.0.2, Constructing IOS keep alive payload: proposal=32767/32767 sec.
Mar 03 13:18:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, constructing dpd vid payload
Mar 03 13:18:47 [IKEv1]IP = 7.1.0.2, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + ID (5) + HASH (8) + IOS KEEPALIVE (128) + VENDOR (13) + NONE (0) total length : 92
Mar 03 13:18:47 [IKEv1]Group = DefaultL2LGroup, IP = 7.1.0.2, PHASE 1 COMPLETED
Mar 03 13:18:47 [IKEv1]IP = 7.1.0.2, Keep-alive type for this connection: DPD
Mar 03 13:18:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, Starting P1 rekey timer: 24480 seconds.
Mar 03 13:18:47 [IKEv1 DECODE]IP = 7.1.0.2, IKE Responder starting QM: msg id = 9389754e
Mar 03 13:18:47 [IKEv1]IP = 7.1.0.2, IKE_DECODE RECEIVED Message (msgid=9389754e) with payloads : HDR + HASH (8) + SA (1) + NONCE (10) + ID (5) + ID (5) + NOTIFY (11) + NONE (0) total length : 184
Mar 03 13:18:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, processing SA payload
Mar 03 13:18:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, processing nonce payload
7.1.0.2
Mar 03 13:18:47 [IKEv1]Group = DefaultL2LGroup, IP = 7.1.0.2, Received remote Proxy Host data in ID Payload:  Address 7.1.0.2, Protocol 0, Port 0
7.0.0.2
Mar 03 13:18:47 [IKEv1]Group = DefaultL2LGroup, IP = 7.1.0.2, Received local Proxy Host data in ID Payload:  Address 7.0.0.2, Protocol 0, Port 0
Mar 03 13:18:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, processing notify payload
Mar 03 13:18:47 [IKEv1]Group = DefaultL2LGroup, IP = 7.1.0.2, QM IsRekeyed old sa not found by addr
Mar 03 13:18:47 [IKEv1]Group = DefaultL2LGroup, IP = 7.1.0.2, Skipping dynamic map DYNMAP sequence 10: access-list mismatch.
Mar 03 13:18:47 [IKEv1]Group = DefaultL2LGroup, IP = 7.1.0.2, Rejecting IPSec tunnel: no matching crypto map entry for remote proxy 7.1.0.2/255.255.255.255/0/0 local proxy 7.0.0.2/255.255.255.255/0/0 on interface Outside
Mar 03 13:18:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, sending notify message
Mar 03 13:18:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, constructing blank hash payload
Mar 03 13:18:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, constructing qm hash payload
Mar 03 13:18:47 [IKEv1]IP = 7.1.0.2, IKE_DECODE SENDING Message (msgid=ee315fa4) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 236
Mar 03 13:18:47 [IKEv1]Group = DefaultL2LGroup, IP = 7.1.0.2, QM FSM error (P2 struct &0x00007fffa05e1840, mess id 0x9389754e)!
Mar 03 13:18:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, IKE QM Responder FSM error history (struct &0x00007fffa05e1840)  <state>, <event>:  QM_DONE, EV_ERROR-->QM_BLD_MSG2, EV_NEGO_SA-->QM_BLD_MSG2, EV_IS_REKEY-->QM_BLD_MSG2, EV_CONFIRM_SA-->QM_BLD_MSG2, EV_PROC_MSG-->QM_BLD_MSG2, EV_HASH_OK-->QM_BLD_MSG2, NullEvent-->QM_BLD_MSG2, EV_COMP_HASH
Mar 03 13:18:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, sending delete/delete with reason message
Mar 03 13:18:47 [IKEv1]Group = DefaultL2LGroup, IP = 7.1.0.2, Removing peer from correlator table failed, no match!
Mar 03 13:18:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, IKE SA MM:7adaeddd rcv'd Terminate: state MM_ACTIVE  flags 0x0001c042, refcnt 1, tuncnt 0
Mar 03 13:18:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, IKE SA MM:7adaeddd terminating:  flags 0x0101c002, refcnt 0, tuncnt 0
Mar 03 13:18:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, constructing IKE delete payload
Mar 03 13:18:47 [IKEv1]IP = 7.1.0.2, IKE_DECODE SENDING Message (msgid=f9d973c5) with payloads : HDR + HASH (8) + DELETE (12) + NONE (0) total length : 76
Mar 03 13:18:47 [IKEv1]Group = DefaultL2LGroup, IP = 7.1.0.2, Session is being torn down. Reason: crypto map policy not found
Mar 03 13:18:47 [IKEv1]Ignoring msg to mark SA with dsID 200704 dead because SA deleted
Mar 03 13:18:47 [IKEv1]IP = 7.1.0.2, Received encrypted packet with no matching SA, dropping
Mar 03 13:19:17 [IKEv1]IP = 7.1.0.2, IKE_DECODE RECEIVED Message (msgid=0) with payloads : HDR + SA (1) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NONE (0) total length : 168
Mar 03 13:19:17 [IKEv1 DEBUG]IP = 7.1.0.2, processing SA payload
Mar 03 13:19:17 [IKEv1 DEBUG]IP = 7.1.0.2, Oakley proposal is acceptable
Mar 03 13:19:17 [IKEv1 DEBUG]IP = 7.1.0.2, processing VID payload
Mar 03 13:19:17 [IKEv1 DEBUG]IP = 7.1.0.2, Received NAT-Traversal ver 02 VID
Mar 03 13:19:17 [IKEv1 DEBUG]IP = 7.1.0.2, Received NAT-Traversal ver 03 VID
Mar 03 13:19:17 [IKEv1 DEBUG]IP = 7.1.0.2, Received NAT-Traversal RFC VID
Mar 03 13:19:17 [IKEv1 DEBUG]IP = 7.1.0.2, Received Fragmentation VID
Mar 03 13:19:17 [IKEv1 DEBUG]IP = 7.1.0.2, IKE Peer included IKE fragmentation capability flags:  Main Mode:        True  Aggressive Mode:  True
Mar 03 13:19:17 [IKEv1 DEBUG]IP = 7.1.0.2, processing IKE SA payload
Mar 03 13:19:17 [IKEv1 DEBUG]IP = 7.1.0.2, IKE SA Proposal # 1, Transform # 1 acceptable  Matches global IKE entry # 2
Mar 03 13:19:17 [IKEv1 DEBUG]IP = 7.1.0.2, constructing ISAKMP SA payload
Mar 03 13:19:17 [IKEv1 DEBUG]IP = 7.1.0.2, constructing NAT-Traversal VID ver RFC payload
Mar 03 13:19:17 [IKEv1 DEBUG]IP = 7.1.0.2, constructing Fragmentation VID + extended capabilities payload
Mar 03 13:19:17 [IKEv1]IP = 7.1.0.2, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + SA (1) + VENDOR (13) + VENDOR (13) + NONE (0) total length : 124
Mar 03 13:19:17 [IKEv1]IP = 7.1.0.2, IKE_DECODE RECEIVED Message (msgid=0) with payloads : HDR + KE (4) + NONCE (10) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NAT-D (20) + NAT-D (20) + NONE (0) total length : 296
Mar 03 13:19:17 [IKEv1 DEBUG]IP = 7.1.0.2, processing ke payload
Mar 03 13:19:17 [IKEv1 DEBUG]IP = 7.1.0.2, processing ISA_KE payload
Mar 03 13:19:17 [IKEv1 DEBUG]IP = 7.1.0.2, processing nonce payload
Mar 03 13:19:17 [IKEv1 DEBUG]IP = 7.1.0.2, Received Cisco Unity client VID
Mar 03 13:19:17 [IKEv1 DEBUG]IP = 7.1.0.2, Received xauth V6 VID
Mar 03 13:19:17 [IKEv1 DEBUG]IP = 7.1.0.2, Processing VPN3000/ASA spoofing IOS Vendor ID payload (version: 1.0.0, capabilities: 20000001)
Mar 03 13:19:17 [IKEv1 DEBUG]IP = 7.1.0.2, Received Altiga/Cisco VPN3000/Cisco ASA GW VID
Mar 03 13:19:17 [IKEv1 DEBUG]IP = 7.1.0.2, processing NAT-Discovery payload
Mar 03 13:19:17 [IKEv1 DEBUG]IP = 7.1.0.2, computing NAT Discovery hash
Mar 03 13:19:17 [IKEv1 DEBUG]IP = 7.1.0.2, constructing ke payload
Mar 03 13:19:17 [IKEv1 DEBUG]IP = 7.1.0.2, constructing nonce payload
Mar 03 13:19:17 [IKEv1 DEBUG]IP = 7.1.0.2, constructing Cisco Unity VID payload
Mar 03 13:19:17 [IKEv1 DEBUG]IP = 7.1.0.2, constructing xauth V6 VID payload
Mar 03 13:19:17 [IKEv1 DEBUG]IP = 7.1.0.2, Send IOS VID
Mar 03 13:19:17 [IKEv1 DEBUG]IP = 7.1.0.2, Constructing ASA spoofing IOS Vendor ID payload (version: 1.0.0, capabilities: 20000001)
Mar 03 13:19:17 [IKEv1 DEBUG]IP = 7.1.0.2, constructing VID payload
Mar 03 13:19:17 [IKEv1 DEBUG]IP = 7.1.0.2, Send Altiga/Cisco VPN3000/Cisco ASA GW VID
Mar 03 13:19:17 [IKEv1 DEBUG]IP = 7.1.0.2, constructing NAT-Discovery payload
Mar 03 13:19:17 [IKEv1]IP = 7.1.0.2, Connection landed on tunnel_group DefaultL2LGroup
Mar 03 13:19:17 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, Generating keys for Responder...
Mar 03 13:19:17 [IKEv1]IP = 7.1.0.2, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + KE (4) + NONCE (10) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NAT-D (20) + NAT-D (20) + NONE (0) total length : 296
Mar 03 13:19:17 [IKEv1]IP = 7.1.0.2, IKE_DECODE RECEIVED Message (msgid=0) with payloads : HDR + ID (5) + HASH (8) + IOS KEEPALIVE (128) + VENDOR (13) + NONE (0) total length : 92
Mar 03 13:19:17 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, processing ID payload
Mar 03 13:19:17 [IKEv1 DECODE]Group = DefaultL2LGroup, IP = 7.1.0.2, ID_IPV4_ADDR ID received
7.1.0.2
Mar 03 13:19:17 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, processing hash payload
Mar 03 13:19:17 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, Computing hash for ISAKMP
Mar 03 13:19:17 [IKEv1 DEBUG]IP = 7.1.0.2, Processing IOS keep alive payload: proposal=32767/32767 sec.
Mar 03 13:19:17 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, processing VID payload
Mar 03 13:19:17 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, Received DPD VID
Mar 03 13:19:17 [IKEv1]Group = DefaultL2LGroup, IP = 7.1.0.2, Automatic NAT Detection Status:     Remote end is NOT behind a NAT device     This   end is NOT behind a NAT device
Mar 03 13:19:17 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, constructing ID payload
Mar 03 13:19:17 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, constructing hash payload
Mar 03 13:19:17 [IKEv1 DEBUG]IP = 7.1.0.2, Constructing IOS keep alive payload: proposal=32767/32767 sec.
Mar 03 13:19:17 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, constructing dpd vid payload
Mar 03 13:19:17 [IKEv1]IP = 7.1.0.2, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + ID (5) + HASH (8) + IOS KEEPALIVE (128) + VENDOR (13) + NONE (0) total length : 92
Mar 03 13:19:17 [IKEv1]Group = DefaultL2LGroup, IP = 7.1.0.2, PHASE 1 COMPLETED
Mar 03 13:19:17 [IKEv1]IP = 7.1.0.2, Keep-alive type for this connection: DPD
Mar 03 13:19:17 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, Starting P1 rekey timer: 24480 seconds.
Mar 03 13:19:17 [IKEv1 DECODE]IP = 7.1.0.2, IKE Responder starting QM: msg id = 3af2253f
Mar 03 13:19:17 [IKEv1]IP = 7.1.0.2, IKE_DECODE RECEIVED Message (msgid=3af2253f) with payloads : HDR + HASH (8) + SA (1) + NONCE (10) + ID (5) + ID (5) + NOTIFY (11) + NONE (0) total length : 184
Mar 03 13:19:17 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, processing SA payload
Mar 03 13:19:17 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, processing nonce payload
7.1.0.2
Mar 03 13:19:17 [IKEv1]Group = DefaultL2LGroup, IP = 7.1.0.2, Received remote Proxy Host data in ID Payload:  Address 7.1.0.2, Protocol 0, Port 0
7.0.0.2
Mar 03 13:19:17 [IKEv1]Group = DefaultL2LGroup, IP = 7.1.0.2, Received local Proxy Host data in ID Payload:  Address 7.0.0.2, Protocol 0, Port 0
Mar 03 13:19:17 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, processing notify payload
Mar 03 13:19:17 [IKEv1]Group = DefaultL2LGroup, IP = 7.1.0.2, QM IsRekeyed old sa not found by addr
Mar 03 13:19:17 [IKEv1]Group = DefaultL2LGroup, IP = 7.1.0.2, Skipping dynamic map DYNMAP sequence 10: access-list mismatch.
Mar 03 13:19:17 [IKEv1]Group = DefaultL2LGroup, IP = 7.1.0.2, Rejecting IPSec tunnel: no matching crypto map entry for remote proxy 7.1.0.2/255.255.255.255/0/0 local proxy 7.0.0.2/255.255.255.255/0/0 on interface Outside
Mar 03 13:19:17 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, sending notify message
Mar 03 13:19:17 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, constructing blank hash payload
Mar 03 13:19:17 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, constructing qm hash payload
Mar 03 13:19:17 [IKEv1]IP = 7.1.0.2, IKE_DECODE SENDING Message (msgid=d4ee1beb) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 236
Mar 03 13:19:17 [IKEv1]Group = DefaultL2LGroup, IP = 7.1.0.2, QM FSM error (P2 struct &0x00007fff9f9787e0, mess id 0x3af2253f)!
Mar 03 13:19:17 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, IKE QM Responder FSM error history (struct &0x00007fff9f9787e0)  <state>, <event>:  QM_DONE, EV_ERROR-->QM_BLD_MSG2, EV_NEGO_SA-->QM_BLD_MSG2, EV_IS_REKEY-->QM_BLD_MSG2, EV_CONFIRM_SA-->QM_BLD_MSG2, EV_PROC_MSG-->QM_BLD_MSG2, EV_HASH_OK-->QM_BLD_MSG2, NullEvent-->QM_BLD_MSG2, EV_COMP_HASH
Mar 03 13:19:17 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, sending delete/delete with reason message
Mar 03 13:19:17 [IKEv1]Group = DefaultL2LGroup, IP = 7.1.0.2, Removing peer from correlator table failed, no match!
Mar 03 13:19:17 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, IKE SA MM:47629a55 rcv'd Terminate: state MM_ACTIVE  flags 0x0001c042, refcnt 1, tuncnt 0
Mar 03 13:19:17 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, IKE SA MM:47629a55 terminating:  flags 0x0101c002, refcnt 0, tuncnt 0
Mar 03 13:19:17 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, constructing IKE delete payload
Mar 03 13:19:17 [IKEv1]IP = 7.1.0.2, IKE_DECODE SENDING Message (msgid=c7a1c363) with payloads : HDR + HASH (8) + DELETE (12) + NONE (0) total length : 76
Mar 03 13:19:17 [IKEv1]Group = DefaultL2LGroup, IP = 7.1.0.2, Session is being torn down. Reason: crypto map policy not found
Mar 03 13:19:17 [IKEv1]Ignoring msg to mark SA with dsID 204800 dead because SA deleted
Mar 03 13:19:17 [IKEv1]IP = 7.1.0.2, Received encrypted packet with no matching SA, dropping
Mar 03 13:19:47 [IKEv1]IP = 7.1.0.2, IKE_DECODE RECEIVED Message (msgid=0) with payloads : HDR + SA (1) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NONE (0) total length : 168
Mar 03 13:19:47 [IKEv1 DEBUG]IP = 7.1.0.2, processing SA payload
Mar 03 13:19:47 [IKEv1 DEBUG]IP = 7.1.0.2, Oakley proposal is acceptable
Mar 03 13:19:47 [IKEv1 DEBUG]IP = 7.1.0.2, processing VID payload
Mar 03 13:19:47 [IKEv1 DEBUG]IP = 7.1.0.2, Received NAT-Traversal ver 02 VID
Mar 03 13:19:47 [IKEv1 DEBUG]IP = 7.1.0.2, Received NAT-Traversal ver 03 VID
Mar 03 13:19:47 [IKEv1 DEBUG]IP = 7.1.0.2, Received NAT-Traversal RFC VID
Mar 03 13:19:47 [IKEv1 DEBUG]IP = 7.1.0.2, Received Fragmentation VID
Mar 03 13:19:47 [IKEv1 DEBUG]IP = 7.1.0.2, IKE Peer included IKE fragmentation capability flags:  Main Mode:        True  Aggressive Mode:  True
Mar 03 13:19:47 [IKEv1 DEBUG]IP = 7.1.0.2, processing IKE SA payload
Mar 03 13:19:47 [IKEv1 DEBUG]IP = 7.1.0.2, IKE SA Proposal # 1, Transform # 1 acceptable  Matches global IKE entry # 2
Mar 03 13:19:47 [IKEv1 DEBUG]IP = 7.1.0.2, constructing ISAKMP SA payload
Mar 03 13:19:47 [IKEv1 DEBUG]IP = 7.1.0.2, constructing NAT-Traversal VID ver RFC payload
Mar 03 13:19:47 [IKEv1 DEBUG]IP = 7.1.0.2, constructing Fragmentation VID + extended capabilities payload
Mar 03 13:19:47 [IKEv1]IP = 7.1.0.2, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + SA (1) + VENDOR (13) + VENDOR (13) + NONE (0) total length : 124
Mar 03 13:19:47 [IKEv1]IP = 7.1.0.2, IKE_DECODE RECEIVED Message (msgid=0) with payloads : HDR + KE (4) + NONCE (10) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NAT-D (20) + NAT-D (20) + NONE (0) total length : 296
Mar 03 13:19:47 [IKEv1 DEBUG]IP = 7.1.0.2, processing ke payload
Mar 03 13:19:47 [IKEv1 DEBUG]IP = 7.1.0.2, processing ISA_KE payload
Mar 03 13:19:47 [IKEv1 DEBUG]IP = 7.1.0.2, processing nonce payload
Mar 03 13:19:47 [IKEv1 DEBUG]IP = 7.1.0.2, Received Cisco Unity client VID
Mar 03 13:19:47 [IKEv1 DEBUG]IP = 7.1.0.2, Received xauth V6 VID
Mar 03 13:19:47 [IKEv1 DEBUG]IP = 7.1.0.2, Processing VPN3000/ASA spoofing IOS Vendor ID payload (version: 1.0.0, capabilities: 20000001)
Mar 03 13:19:47 [IKEv1 DEBUG]IP = 7.1.0.2, Received Altiga/Cisco VPN3000/Cisco ASA GW VID
Mar 03 13:19:47 [IKEv1 DEBUG]IP = 7.1.0.2, processing NAT-Discovery payload
Mar 03 13:19:47 [IKEv1 DEBUG]IP = 7.1.0.2, computing NAT Discovery hash
Mar 03 13:19:47 [IKEv1 DEBUG]IP = 7.1.0.2, constructing ke payload
Mar 03 13:19:47 [IKEv1 DEBUG]IP = 7.1.0.2, constructing nonce payload
Mar 03 13:19:47 [IKEv1 DEBUG]IP = 7.1.0.2, constructing Cisco Unity VID payload
Mar 03 13:19:47 [IKEv1 DEBUG]IP = 7.1.0.2, constructing xauth V6 VID payload
Mar 03 13:19:47 [IKEv1 DEBUG]IP = 7.1.0.2, Send IOS VID
Mar 03 13:19:47 [IKEv1 DEBUG]IP = 7.1.0.2, Constructing ASA spoofing IOS Vendor ID payload (version: 1.0.0, capabilities: 20000001)
Mar 03 13:19:47 [IKEv1 DEBUG]IP = 7.1.0.2, constructing VID payload
Mar 03 13:19:47 [IKEv1 DEBUG]IP = 7.1.0.2, Send Altiga/Cisco VPN3000/Cisco ASA GW VID
Mar 03 13:19:47 [IKEv1 DEBUG]IP = 7.1.0.2, constructing NAT-Discovery payload
Mar 03 13:19:47 [IKEv1]IP = 7.1.0.2, Connection landed on tunnel_group DefaultL2LGroup
Mar 03 13:19:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, Generating keys for Responder...
Mar 03 13:19:47 [IKEv1]IP = 7.1.0.2, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + KE (4) + NONCE (10) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NAT-D (20) + NAT-D (20) + NONE (0) total length : 296
Mar 03 13:19:47 [IKEv1]IP = 7.1.0.2, IKE_DECODE RECEIVED Message (msgid=0) with payloads : HDR + ID (5) + HASH (8) + IOS KEEPALIVE (128) + VENDOR (13) + NONE (0) total length : 92
Mar 03 13:19:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, processing ID payload
Mar 03 13:19:47 [IKEv1 DECODE]Group = DefaultL2LGroup, IP = 7.1.0.2, ID_IPV4_ADDR ID received
7.1.0.2
Mar 03 13:19:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, processing hash payload
Mar 03 13:19:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, Computing hash for ISAKMP
Mar 03 13:19:47 [IKEv1 DEBUG]IP = 7.1.0.2, Processing IOS keep alive payload: proposal=32767/32767 sec.
Mar 03 13:19:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, processing VID payload
Mar 03 13:19:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, Received DPD VID
Mar 03 13:19:47 [IKEv1]Group = DefaultL2LGroup, IP = 7.1.0.2, Automatic NAT Detection Status:     Remote end is NOT behind a NAT device     This   end is NOT behind a NAT device
Mar 03 13:19:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, constructing ID payload
Mar 03 13:19:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, constructing hash payload
Mar 03 13:19:47 [IKEv1 DEBUG]IP = 7.1.0.2, Constructing IOS keep alive payload: proposal=32767/32767 sec.
Mar 03 13:19:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, constructing dpd vid payload
Mar 03 13:19:47 [IKEv1]IP = 7.1.0.2, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + ID (5) + HASH (8) + IOS KEEPALIVE (128) + VENDOR (13) + NONE (0) total length : 92
Mar 03 13:19:47 [IKEv1]Group = DefaultL2LGroup, IP = 7.1.0.2, PHASE 1 COMPLETED
Mar 03 13:19:47 [IKEv1]IP = 7.1.0.2, Keep-alive type for this connection: DPD
Mar 03 13:19:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, Starting P1 rekey timer: 24480 seconds.
Mar 03 13:19:47 [IKEv1 DECODE]IP = 7.1.0.2, IKE Responder starting QM: msg id = 3383044c
Mar 03 13:19:47 [IKEv1]IP = 7.1.0.2, IKE_DECODE RECEIVED Message (msgid=3383044c) with payloads : HDR + HASH (8) + SA (1) + NONCE (10) + ID (5) + ID (5) + NOTIFY (11) + NONE (0) total length : 184
Mar 03 13:19:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, processing SA payload
Mar 03 13:19:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, processing nonce payload
7.1.0.2
Mar 03 13:19:47 [IKEv1]Group = DefaultL2LGroup, IP = 7.1.0.2, Received remote Proxy Host data in ID Payload:  Address 7.1.0.2, Protocol 0, Port 0
7.0.0.2
Mar 03 13:19:47 [IKEv1]Group = DefaultL2LGroup, IP = 7.1.0.2, Received local Proxy Host data in ID Payload:  Address 7.0.0.2, Protocol 0, Port 0
Mar 03 13:19:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, processing notify payload
Mar 03 13:19:47 [IKEv1]Group = DefaultL2LGroup, IP = 7.1.0.2, QM IsRekeyed old sa not found by addr
Mar 03 13:19:47 [IKEv1]Group = DefaultL2LGroup, IP = 7.1.0.2, Skipping dynamic map DYNMAP sequence 10: access-list mismatch.
Mar 03 13:19:47 [IKEv1]Group = DefaultL2LGroup, IP = 7.1.0.2, Rejecting IPSec tunnel: no matching crypto map entry for remote proxy 7.1.0.2/255.255.255.255/0/0 local proxy 7.0.0.2/255.255.255.255/0/0 on interface Outside
Mar 03 13:19:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, sending notify message
Mar 03 13:19:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, constructing blank hash payload
Mar 03 13:19:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, constructing qm hash payload
Mar 03 13:19:47 [IKEv1]IP = 7.1.0.2, IKE_DECODE SENDING Message (msgid=f717942f) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 236
Mar 03 13:19:47 [IKEv1]Group = DefaultL2LGroup, IP = 7.1.0.2, QM FSM error (P2 struct &0x00007fff9f9787e0, mess id 0x3383044c)!
Mar 03 13:19:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, IKE QM Responder FSM error history (struct &0x00007fff9f9787e0)  <state>, <event>:  QM_DONE, EV_ERROR-->QM_BLD_MSG2, EV_NEGO_SA-->QM_BLD_MSG2, EV_IS_REKEY-->QM_BLD_MSG2, EV_CONFIRM_SA-->QM_BLD_MSG2, EV_PROC_MSG-->QM_BLD_MSG2, EV_HASH_OK-->QM_BLD_MSG2, NullEvent-->QM_BLD_MSG2, EV_COMP_HASH
Mar 03 13:19:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, sending delete/delete with reason message
Mar 03 13:19:47 [IKEv1]Group = DefaultL2LGroup, IP = 7.1.0.2, Removing peer from correlator table failed, no match!
Mar 03 13:19:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, IKE SA MM:74a1793f rcv'd Terminate: state MM_ACTIVE  flags 0x0001c042, refcnt 1, tuncnt 0
Mar 03 13:19:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, IKE SA MM:74a1793f terminating:  flags 0x0101c002, refcnt 0, tuncnt 0
Mar 03 13:19:47 [IKEv1 DEBUG]Group = DefaultL2LGroup, IP = 7.1.0.2, constructing IKE delete payload
Mar 03 13:19:47 [IKEv1]IP = 7.1.0.2, IKE_DECODE SENDING Message (msgid=883e1938) with payloads : HDR + HASH (8) + DELETE (12) + NONE (0) total length : 76
Mar 03 13:19:47 [IKEv1]Group = DefaultL2LGroup, IP = 7.1.0.2, Session is being torn down. Reason: crypto map policy not found
Mar 03 13:19:47 [IKEv1]Ignoring msg to mark SA with dsID 208896 dead because SA deleted
Mar 03 13:19:47 [IKEv1]IP = 7.1.0.2, Received encrypted packet with no matching SA, dropping
ASA1# undebug all
ASA1#
ASA2#
ASA2#
ASA2# debug crypto isakmp 127
ASA2# Mar 03 08:58:34 [IKEv1 DEBUG]: Pitcher: received a key acquire message, spi 0x0
Mar 03 08:58:34 [IKEv1]: IP = 7.0.0.2, IKE Initiator: New Phase 1, Intf Outside, IKE Peer 7.0.0.2  local Proxy Address 7.1.0.2, remote Proxy Address 7.0.0.2,  Crypto map (HQ2REMOTE)
Mar 03 08:58:34 [IKEv1 DEBUG]: IP = 7.0.0.2, constructing ISAKMP SA payload
Mar 03 08:58:34 [IKEv1 DEBUG]: IP = 7.0.0.2, constructing NAT-Traversal VID ver 02 payload
Mar 03 08:58:34 [IKEv1 DEBUG]: IP = 7.0.0.2, constructing NAT-Traversal VID ver 03 payload
Mar 03 08:58:34 [IKEv1 DEBUG]: IP = 7.0.0.2, constructing NAT-Traversal VID ver RFC payload
Mar 03 08:58:34 [IKEv1 DEBUG]: IP = 7.0.0.2, constructing Fragmentation VID + extended capabilities payload
Mar 03 08:58:34 [IKEv1]: IP = 7.0.0.2, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + SA (1) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NONE (0) total length : 168
Mar 03 08:58:34 [IKEv1]: IP = 7.0.0.2, IKE_DECODE RECEIVED Message (msgid=0) with payloads : HDR + SA (1) + VENDOR (13) + VENDOR (13) + NONE (0) total length : 124
Mar 03 08:58:34 [IKEv1 DEBUG]: IP = 7.0.0.2, processing SA payload
Mar 03 08:58:34 [IKEv1 DEBUG]: IP = 7.0.0.2, Oakley proposal is acceptable
Mar 03 08:58:34 [IKEv1 DEBUG]: IP = 7.0.0.2, processing VID payload
Mar 03 08:58:34 [IKEv1 DEBUG]: IP = 7.0.0.2, Received NAT-Traversal RFC VID
Mar 03 08:58:34 [IKEv1 DEBUG]: IP = 7.0.0.2, Received Fragmentation VID
Mar 03 08:58:34 [IKEv1 DEBUG]: IP = 7.0.0.2, IKE Peer included IKE fragmentation capability flags:  Main Mode:        True  Aggressive Mode:  True
Mar 03 08:58:34 [IKEv1 DEBUG]: IP = 7.0.0.2, constructing ke payload
Mar 03 08:58:34 [IKEv1 DEBUG]: IP = 7.0.0.2, constructing nonce payload
Mar 03 08:58:34 [IKEv1 DEBUG]: IP = 7.0.0.2, constructing Cisco Unity VID payload
Mar 03 08:58:34 [IKEv1 DEBUG]: IP = 7.0.0.2, constructing xauth V6 VID payload
Mar 03 08:58:34 [IKEv1 DEBUG]: IP = 7.0.0.2, Send IOS VID
Mar 03 08:58:34 [IKEv1 DEBUG]: IP = 7.0.0.2, Constructing ASA spoofing IOS Vendor ID payload (version: 1.0.0, capabilities: 20000001)
Mar 03 08:58:34 [IKEv1 DEBUG]: IP = 7.0.0.2, constructing VID payload
Mar 03 08:58:34 [IKEv1 DEBUG]: IP = 7.0.0.2, Send Altiga/Cisco VPN3000/Cisco ASA GW VID
Mar 03 08:58:34 [IKEv1 DEBUG]: IP = 7.0.0.2, constructing NAT-Discovery payload
Mar 03 08:58:34 [IKEv1 DEBUG]: IP = 7.0.0.2, computing NAT Discovery hash
Mar 03 08:58:34 [IKEv1]: IP = 7.0.0.2, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + KE (4) + NONCE (10) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NAT-D (20) + NAT-D (20) + NONE (0) total length : 296
Mar 03 08:58:34 [IKEv1]: IP = 7.0.0.2, IKE_DECODE RECEIVED Message (msgid=0) with payloads : HDR + KE (4) + NONCE (10) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NAT-D (20) + NAT-D (20) + NONE (0) total length : 296
Mar 03 08:58:34 [IKEv1 DEBUG]: IP = 7.0.0.2, processing ke payload
Mar 03 08:58:34 [IKEv1 DEBUG]: IP = 7.0.0.2, processing ISA_KE payload
Mar 03 08:58:34 [IKEv1 DEBUG]: IP = 7.0.0.2, processing nonce payload
Mar 03 08:58:34 [IKEv1 DEBUG]: IP = 7.0.0.2, Received Cisco Unity client VID
Mar 03 08:58:34 [IKEv1 DEBUG]: IP = 7.0.0.2, Received xauth V6 VID
Mar 03 08:58:34 [IKEv1 DEBUG]: IP = 7.0.0.2, Processing VPN3000/ASA spoofing IOS Vendor ID payload (version: 1.0.0, capabilities: 20000001)
Mar 03 08:58:34 [IKEv1 DEBUG]: IP = 7.0.0.2, Received Altiga/Cisco VPN3000/Cisco ASA GW VID
Mar 03 08:58:34 [IKEv1 DEBUG]: IP = 7.0.0.2, processing NAT-Discovery payload
ASA2# : IP = 7.0.0.2, processing NAT-Discovery payload
Mar 03 08:58:34 [IKEv1]: IP = 7.0.0.2, Connection landed on tunnel_group 7.0.0.2
Mar 03 08:58:34 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, Generating keys for Initiator...
Mar 03 08:58:34 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, constructing ID payload
Mar 03 08:58:34 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, constructing hash payload
Mar 03 08:58:34 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, Computing hash for ISAKMP
Mar 03 08:58:34 [IKEv1 DEBUG]: IP = 7.0.0.2, Constructing IOS keep alive payload: proposal=32767/32767 sec.
Mar 03 08:58:34 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, constructing dpd vid payload
Mar 03 08:58:34 [IKEv1]: IP = 7.0.0.2, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + ID (5) + HASH (8) + IOS KEEPALIVE (128) + VENDOR (13) + NONE (0) total length : 92
Mar 03 08:58:34 [IKEv1]: Group = 7.0.0.2, IP = 7.0.0.2, Automatic NAT Detection Status:     Remote end is NOT behind a NAT device     This   end is NOT behind a NAT device
Mar 03 08:58:34 [IKEv1]: IP = 7.0.0.2, IKE_DECODE RECEIVED Message (msgid=0) with payloads : HDR + ID (5) + HASH (8) + IOS KEEPALIVE (128) + VENDOR (13) + NONE (0) total length : 92
Mar 03 08:58:34 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, processing ID payload
Mar 03 08:58:34 [IKEv1 DECODE]: Group = 7.0.0.2, IP = 7.0.0.2, ID_IPV4_ADDR ID received
7.0.0.2
Mar 03 08:58:34 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, processing hash payload
Mar 03 08:58:34 [IKEv1 DEBUG]: IP = 7.0.0.2, Processing IOS keep alive payload: proposal=32767/32767 sec.
Mar 03 08:58:34 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, processing VID payload
Mar 03 08:58:34 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, Received DPD VID
Mar 03 08:58:34 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, Oakley begin quick mode
Mar 03 08:58:34 [IKEv1 DECODE]: Group = 7.0.0.2, IP = 7.0.0.2, IKE Initiator starting QM: msg id = ea585f90
Mar 03 08:58:34 [IKEv1]: Group = 7.0.0.2, IP = 7.0.0.2, PHASE 1 COMPLETED
Mar 03 08:58:34 [IKEv1]: IP = 7.0.0.2, Keep-alive type for this connection: DPD
Mar 03 08:58:34 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, Starting P1 rekey timer: 27360 seconds.
Mar 03 08:58:34 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, IKE got SPI from key engine: SPI = 0xe5aab4b5
Mar 03 08:58:34 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, oakley constucting quick mode
Mar 03 08:58:34 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, constructing blank hash payload
Mar 03 08:58:34 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, constructing IPSec SA payload
Mar 03 08:58:34 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, constructing IPSec nonce payload
Mar 03 08:58:34 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, constructing proxy ID
Mar 03 08:58:34 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, Transmitting Proxy Id:
  Local host:  7.1.0.2  Protocol 0  Port 0
  Remote host: 7.0.0.2  Protocol 0  Port 0
Mar 03 08:58:34 [IKEv1 DECODE]: Group = 7.0.0.2, IP = 7.0.0.2, IKE Initiator sending Initial Contact
Mar 03 08:58:34 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, constructing qm hash payload
Mar 03 08:58:34 [IKEv1 DECODE]: Group = 7.0.0.2, IP = 7.0.0.2, IKE Initiator sending 1st QM pkt: msg id = ea585f90
Mar 03 08:58:34 [IKEv1]: IP = 7.0.0.2, IKE_DECODE SENDING Message (msgid=ea585f90) with payloads : HDR + HASH (8) + SA (1) + NONCE (10) + ID (5) + ID (5) + NOTIFY (11) + NONE (0) total length : 184
Mar 03 08:58:34 [IKEv1]: IP = 7.0.0.2, IKE_DECODE RECEIVED Message (msgid=602db3a7) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 236
Mar 03 08:58:34 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, processing notify payload
Mar 03 08:58:34 [IKEv1]: Group = 7.0.0.2, IP = 7.0.0.2, Received non-routine Notify message: Invalid ID info (18)
Mar 03 08:58:34 [IKEv1]: IP = 7.0.0.2, IKE_DECODE RECEIVED Message (msgid=29ddd81f) with payloads : HDR + HASH (8) + DELETE (12) + NONE (0) total length : 76
Mar 03 08:58:34 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, processing delete
Mar 03 08:58:34 [IKEv1]: Group = 7.0.0.2, IP = 7.0.0.2, Connection terminated for peer 7.0.0.2.  Reason: Peer Terminate  Remote Proxy N/A, Local Proxy N/A
Mar 03 08:58:34 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, sending delete/delete with reason message
Mar 03 08:58:34 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, constructing IPSec delete payload
Mar 03 08:58:34 [IKEv1]: IP = 7.0.0.2, IKE_DECODE SENDING Message (msgid=2a8b25a9) with payloads : HDR + HASH (8) + DELETE (12) + NONE (0) total length : 64
Mar 03 08:58:34 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, IKE Deleting SA: Remote Proxy 7.0.0.2, Local Proxy 7.1.0.2
Mar 03 08:58:34 [IKEv1]: Group = 7.0.0.2, IP = 7.0.0.2, Removing peer from correlator table failed, no match!
Mar 03 08:58:34 [IKEv1 DEBUG]: Group = 7.0.0.2, IP = 7.0.0.2, IKE SA MM:7362cee8 terminating:  flags 0x0100c822, refcnt 0, tuncnt 0
Mar 03 08:58:34 [IKEv1]: Group = 7.0.0.2, IP = 7.0.0.2, Session is being torn down. Reason: User Requested
Mar 03 08:58:34 [IKEv1]: Ignoring msg to mark SA with dsID 217088 dead because SA deleted
Mar 03 08:58:34 [IKEv1 DEBUG]: Pitcher: received key delete msg, spi 0xe5aab4b5
ASA2# undebug all
ASA2#
Ken
Ken
But now it is using the right group which means the two firewalls recognise this is a L2L tunnel and not a remote access one which is what we've be trying to do for a while now.
Let me have a look at the debugs and your configs and i'll get back to you soon.
Jon
