01-13-2006 05:15 AM
When the dialing router initiate to the receiving router, it gives an error message below at the receiving router end:
*Jan 13 09:09:41.522: ISDN Se1/0:15 Q931: RX <- SETUP pd = 8 callref = 0x00E0
Sending Complete
Bearer Capability i = 0x8890
Standard = CCITT
Transfer Capability = Unrestricted Digital
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA1839E
Preferred, Channel 30
Calling Party Number i = 0x0183, '03771820900'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x81, '2030'
*Jan 13 09:09:41.526: ISDN Se1/0:15 EVENT: process_rxstate: ces/callid 1/0x93 calltype 1 CALL_INCOMING
*Jan 13 09:09:41.526: ISDN Se1/0:15 EVENT: call_incoming: call_id 0x0093, Guid = 005D3B29426A
*Jan 13 09:09:41.526: ISDN Se1/0:29: Incoming call rejected, unbindable
*Jan 13 09:09:41.526: ISDN Se1/0:15 **ERROR**: call_incoming: DIALER ERROR 0x1: b channel 29 call id 0x93
*Jan 13 09:09:41.530: ISDN Se1/0:15 EVENT: process_rxstate: ces/callid 1/0x93 calltype 1 CALL_CLEARED
*Jan 13 09:09:41.546: ISDN Se1/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x80E0
Cause i = 0x8095 - Call rejected
Whats does that means??
01-13-2006 05:58 AM
most likely, there is a problem with the dialer interface bound to a physicall interface. Check if the physical interfaces have the command 'dialer pool-member' configured, and the corresponding dialer interfaces the 'dialer pool', as in this example:
interface BRI0/0
dialer pool-member 1
interface Dialer1
dialer pool 1
GP
01-13-2006 06:28 AM
The receiving router dialer config as below.(the router will be accepting calls from 2 remote site)
interface Serial1/0:15
no ip address
encapsulation ppp
isdn switch-type primary-net5
ppp multilink
interface Dialer1
ip address 1.188.8.2 255.255.255.248
encapsulation ppp
dialer pool 1
dialer idle-timeout 60
dialer load-threshold 1 outbound
dialer-group 1
ppp authentication chap
interface Dialer2
encapsulation ppp
dialer pool 1
dialer-group 1
01-13-2006 06:52 AM
on your dialer interfaces, you need to specify the remote name of the device calling in, e.g.:
interface Dialer1
ip address 1.x.x.x.255.255.248
encapsulation ppp
dialer pool 1
dialer remote-name Branch_Router
dialer-group 1
Also, make sure that the local username and password are configured:
username Branch_Router password 0 cisco
On the branch router, you need to do the same, with the username being the name of the central router. The passwords need to match, and are case- sensitive:
So, if your central office router´s hostname is ´Central_Router´, the following needs to be configured on the branch router:
Branch_Router
username Central_Router password 0 cisco
HTH,
GP
01-13-2006 08:40 AM
i've tried, it's the same error..
i'm just wondering is there any error on my dialer config?? coz its sharing same dialer pool ??
01-13-2006 10:02 AM
at second glance, I would say yes: the IP addresses on both dialer interfaces are identical, you might want to change those...
HTH,
GP
01-16-2006 10:23 AM
have tried to change the IP address..its the same result..
but i've tried something else..
i removed dialer pool 1 and dialer-group 1 in the int dialer 2..and it managed to dialed in but cannot be bind to a dialer...
any idea what is configured wrongly??
01-16-2006 11:31 AM
have you configured the ´dialer remote-name´ on the dialer interfaces ?
GP
01-16-2006 08:16 PM
yup..i've entered the dialer remote name..but still the same...
anything that i configured wrongly??
01-18-2006 05:13 AM
What's missing from your config is the "ppp authentication chap" command on the D-channel of your PRI ie. Serial 1/0:15.
Then add the "dialer remote-name
That should solve your problem.
Pls rate this post if it helps.
01-19-2006 08:41 AM
nbhandarker,
thank you..
you are my hero..
you solved my problem..
but how can i rate it??
