05-11-2022 02:55 AM
I have issue regarding Crypto map VPN between cisco ISR 4433 router and Mikrotik Router..
Issue is that Phase 2 is not up...
Relevant config
crypto isakmp profile IKEV1_PROFILE_CRYPTOMAP vrf SILK keyring IKEv1_KEYRING1 match identity address XX.XX.XX.XX 255.255.255.255 crypto keyring IKEv1_KEYRING1 vrf VRF pre-shared-key address XX.XX.XX.XX key crypto map CRYPTO_VRF 2 ipsec-isakmp set peer XX.XX.XX.XX set transform-set ESP-AES256-SHA256 set pfs group14 set isakmp-profile IKEV1_PROFILE_CRYPTOMAP match address CRYPTOMAP reverse-route
Below is output of debug crypto ipsec
May 11 2022 13:50:00.957 TBS: IPSEC(validate_proposal_request): proposal part #1,
(key eng. msg.) INBOUND local= CISCO_PUBLIC_IP:0, remote= MIKROTIK_PUBLIC_IP:0,
local_proxy= 10.11.11.11/255.255.255.255/256/0,
remote_proxy= 10.11.11.15/255.255.255.255/256/0,
protocol= ESP, transform= esp-aes 256 esp-sha256-hmac (Tunnel), esn= FALSE,
lifedur= 0s and 0kb,
spi= 0x0(0), conn_id= 0, keysize= 256, flags= 0x0
May 11 2022 13:50:00.957 TBS: Crypto mapdb : proxy_match
src addr : 10.11.11.11
dst addr : 10.11.11.15
protocol : 0
src port : 0
dst port : 0
May 11 2022 13:50:00.958 TBS: Crypto mapdb : proxy_match
protocol : 0
src port : 0
dst port : 0
May 11 2022 13:50:00.958 TBS: IPSEC(ipsec_process_proposal): peer address MIKROTIK_PUBLIC_IP not found
May 11 2022 13:50:00.959 TBS: IPSEC(crypto_ipsec_validate_proposal_request): duplicate/invalid transform requested: prot 3, trans 13, hmac 5
May 11 2022 13:50:00.960 TBS: IPSEC(crypto_ipsec_validate_proposal_request): duplicate/invalid transform requested: prot 3, trans 13, hmac 5
May 11 2022 13:50:00.961 TBS: IPSEC(validate_proposal_request): proposal part #1,
protocol= ESP, transform= esp-gcm 256 (Tunnel), esn= FALSE,
May 11 2022 13:50:00.961 TBS: Crypto mapdb : proxy_match
protocol : 0
src port : 0
dst port : 0
protocol : 0
src port : 0
dst port : 0
ROUTER#
May 11 2022 13:50:00.961 TBS: IPSEC(ipsec_process_proposal): peer address MIKROTIK_PUBLIC_IP not found
May 11 2022 13:50:00.962 TBS: IPSEC(crypto_ipsec_validate_proposal_request): duplicate/invalid transform requested: prot 3, trans 20, hmac 0
05-11-2022 03:29 AM - edited 05-11-2022 03:30 AM
May 11 2022 13:50:00.958 TBS: IPSEC(ipsec_process_proposal): peer address MIKROTIK_PUBLIC_IP not found May 11 2022 13:50:00.959 TBS: IPSEC(crypto_ipsec_validate_proposal_request): duplicate/invalid transform requested: prot 3, trans 13, hmac 5 May 11 2022 13:50:00.960 TBS: IPSEC(crypto_ipsec_validate_proposal_request): duplicate/invalid transform requested: prot 3, trans 13, hmac 5
i would revisit the config :
https://www.youtube.com/watch?v=JsUgRvOWMe8
https://www.youtube.com/watch?v=UZu6cfr8RGM
05-11-2022 03:47 AM
See the thing is that, they definitely see each other because phase 1 is up, i too believe it is somehow a configuration issue but since vrf is also included in this, its not so clear and i was looking for configuration confirmation too? if thats possible... i checked cisco vrf aware ipsec guide and did this config according to that but it is currently failing...
05-11-2022 03:55 AM - edited 05-11-2022 04:00 AM
The source IP address is 10.11.11.11 and destination IP is in the same network (10.11.11.15), is that correct?
Provide the configuration of your ACL CRYPTOMAP., this needs to be mirrored on the remote mikrotik end.
Provide some information on the configuration of the remote mikrotik device.
05-11-2022 04:33 AM
Heres Cisco ACL
10 permit ip host 10.11.11.11 host 10.11.11.15
Heres Mikrotik Policy
# PEER TUNNEL SRC-ADDRESS DST-ADDRESS PROTOCOL ACTION LEVEL PH2-COUNT 0 peer1 yes 10.11.11.15/32 10.11.11.11/32 all encrypt require 0
05-11-2022 03:58 AM
since you phase 1 is coming up it has to be the config issue. double check your phase 2 setting are matching on both sides.
05-11-2022 04:37 AM
I did double triple check it, but i cant seem to find issue and i cant figure out what this error log is pointing to... like if it cant find peer that should be problem in crypto map peer configuration no? but it is correct
05-11-2022 04:31 AM
It seem to me one side is behind NAT
so instead config set peer "real IP" change it to be set peer "mapped IP".
05-11-2022 04:52 AM
if that was the case, would phase 1 be up?
also i have access to mikrotik and it has static public ip
05-11-2022 08:05 AM
Yes phase1 is UP but phase2 that check the remote-ID is down,
so either the remote is behind NAT and set peer is misconfig
or NAT-T is not enable.
