08-23-2018 11:31 AM
Dear Community,
Unfortunately I have a relatively urgent situation. I need to enable a VPN connection to our new ASA 5508-X and I'm struggling with the setup.
We have the following architecture:
CLIENT (HomeOffice) <=> Internet <=> Router (FritzBox) <=> ASA5508-X
I already setup a DynDNS for the FritzBox-Router and enabled full-access to ASA5508-X from internet. That means the ASA5508-X should be reachable from outside, with the usage of the DynDNS name of the Fritzbox.
I wanted to use Windows 10 Client for VPN now and asked my self how to access the ASA5508-X. I set all config as described on the ASA, but I wonder what hostname:<Port> I have to use know, since the ASA is only reachable via DynDNS.
Greetings
niLuxx
Solved! Go to Solution.
08-23-2018 02:02 PM
You should have CCO account, or registered user or contact Cisco partner to download.
08-23-2018 12:18 PM
Look at the example :
If you have DynaDNS Setup, that should resolve with your dynamic ip.
so you configured your windows anyconnect client mydomain.com(this is what you register dynadns domain).
08-23-2018 12:21 PM
Do you know where I can get the AnyConnect packages from? The ASA5508-X comes with 2 valid licenses but I'm not allowed to download them
08-23-2018 02:02 PM
