Problem with reverse telnet
I have a problem with a reverse telnet connection.
I have a cisco 2600series and a 2900series switch and i would like to connect each other using this technic.
Actually i take a straight throug ethernet cable and i connect the aux port of 2600 router with the console port of 2900 switch.
I am using the following commands.
On 2600:
interface loopback 0
ip address 10.1.1.1 255.255.255.255
no shut
line aux 0
transport input all
modem InOut
speed 19200
On 2900 switch i don't use any commad. Do i have to write something?
Of course after that i m using the command: telnet 10.1.1.1 2065
After that i m getting the following response:
trying 10.1.1.1:2065..... Open
with the cursor blinking.
It seems like the connection has established, but why i dont' receice a password prompt or something else?
I hit the CTRL-SHIFT-6-x and i m disconnecting from the switch. After that when i type the command: "show session" i see that i have an open connection with the switch. And of course i type the command "disc 1", in order to terminate the sessing.
Can you tell me what wrong am i doing?
Or if there is something missing in the configuration?
So silly implementation, but so difficult to connect.
Elias
Can you please mark you question as answered?
Rgds,
MiKa
8 Replies 8
mrdogantr
Level 6
Level 6
    pc------>2900(aux)---------------------------->2600(console)
connect 2900 and set commands below
line aux 0
privilege level 15
login local
modem InOut
transport input all
transport output all
no shut
(for connect to 2600)
telnet 10.1.1.1  2001
hth
Muammer
Thanks for your reply.
The connection that i want to implement is 2600(aux)------->2900(console) and not the one that you have told me.
I believe that this is the correct order of connection or not?
I have written all these command on router 2600 and the result was that i m getting a prompt for username and password. I type the username and password that i have create on 2600 (i created also on the switch but it doesn't want it.) and i m getting the same cursor blinking message).
It's doesn't work this solution or something i am doing wrong.
Any ideas?
m.kafka
Level 9
Level 9
RJ45 to RJ45 async connection always need a roll-over cable (a RJ45 roll-over is not an ether X-over!):
Roll-Over:
1 - 8
2 - 7
3 - 6
4 - 5
5 - 4
6 - 3
7 - 2
8 - 1
this is because the console and aux on RJ45 have the exact same pin-out, eg. sending on 3, receiving on 6 (sorry can't remenber by heart, could also be the other way round)
so you need to cross-out rx and tx in the cable, which is done with a roll-over cable, you can tell easily on a flat cable if the "noses" of the RJ45 are on the same side of the flat cable (for cisco, roll over cables are typically light-blue and flat):
  \___                              ___/
or you can crimp your own cable like specified above
Rgds,
MiKa
I used a rollover cable and now it is working.
Rgds,
MiKa
How can i mark this thread as answered?
Glad to help
rgds
MiKa
