Problems Configuring ISDN PRI on VWIC-2MFT-E1 Card
LIONEL GRIFFITH
I have a Cisco 3725 router with one VWIC-2MFT-E1 card installed in Slot 0. The router is running IOS image 12.2(15)T14 IP Plus.
I trying to configure the card for ISDN PRI data, and it's not working. Can some time me if I'm missing a configuration step or whether the card will not support ISDN PRI configuration. Thanks
Support information captured from router:
bredebro-47766(config)#controller e1 0/0
bre(config-controller)#pri-group timeslots 1-31
% No DSP resources available.
bredebro-477665#sho controller e1 0/0 brief
E1 0/0 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20020812, FPGA: 11
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
Data in current interval (3 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
markanthony
Looks like you don't have enough DSP resources. Check to make sure you have sufficient resources. Do a "sh diag" and it wil tell you there what you have. The output is a little different for DSP's across routers. Here is one for a 2821
PVDM Slot 0:
48-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
Hardware Revision : 3.2
Part Number : 73-8540-04
Board Revision : A0
Deviation Number : 0
Fab Version : 03
PCB Serial Number : FOC08411C3Q
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Processor type : 00
Product (FRU) Number : PVDM2-48
Version Identifier : NA
EEPROM format version 4
makchitale
Level 6
Level 6
The VWIC-MFT-E1 card is supported as ISDN-PRI only for voice calls, *NOT DATA*.
http://www.cisco.com/en/US/products/hw/routers/ps274/products_tech_note09186a00800b6e0f.shtml
We will need DSPs for supporting voice, so this card can be installed in a NM-HDV2 with DSPs on it
OR if installed in chassis slot then will need some thing like a AIM-ATM-VOICE-30 to provide DSPs for voice.
Thanks, Mak
tepatel
None of the VWICs support data. They only support voice calls with DSP. So in order to have E1 for Data calls, you need to have network modules either NM-1CE1T1-PRI or NM-2CE1U or NM-1FE1CE1U etc..
Hi TEJAL,
the vwic2 in 2800 either does not support data on ISDN? the datasheet does not specify it, like towards in the previous version
thanks.
