Problems with 2851 and PVDM2
arturo.reyna
Hi, I have a 2851 with PVDM2-36DM but I wasn't able to work with them. It takes a long time the handshake, then a low speed connection and finally a disconection.
I want to try with a modemcap for this kind of modem, or any other suggestion? My modem firmware is V3_09.
TIA
paolo bevilacqua
Can you post "show controllers E1" ?
BOT-RAS-PRUEBA#sh controllers e1 1/0
E1 1/0 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Internal.
Module type is Channelized E1/T1 PRI
Version info Firmware: 0000001D, FPGA: C
Hardware revision is 0.0 , Software revision is 29
Protocol revision is 1
number of CLI resets is 1
Last clearing of alarm counters 00:05:43
receive remote alarm : 0,
transmit remote alarm : 0,
receive AIS alarm : 0,
transmit AIS alarm : 0,
loss of frame : 0,
loss of signal : 0,
Loopback test : 0,
transmit AIS in TS 16 : 0,
receive LOMF alarm : 0,
transmit LOMF alarm : 0,
MIB data updated every 10 seconds.
Data in current interval (343 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
BOT-RAS-PRUEBA#
Can you try FW 3.11 ?
