Site to Site VPN problem
Colin Higgins
Level 2
Level 2
I have an old Cisco 1750 router with the VPN module in it with a site-to-site IPSec VPN to a Cisco ASA
There are three tunnels on this router, and two are working. The third tunnel is configured exactly like the other two, but does not seem to be passing traffic. On the remote ASA, if I do a packet-trace input command, everything checks out: the proper ACL/crypto-map is referenced, NAT exemptions are done, and VPN policy cleared. Everything says OK.
If I ping through the remote ASA, I see the traffic going through the tunnel to the remote 1750 router, but nothing comes back. If I do a show crypto isakmp sa I see the tunnel is up. Packets are being encapsulated, but not de-encapsulated.
If I try to open the tunnel from the 1750 router by referencing an interface within the crypto-map range (interface vlan1 192.168.20.1), the tunnel does not come up. I am not sure I can do this, but it is a remote site, and I have few other ways to test.
The tunnel shows up on the 1750, but nothing is being encapsulated/encrypted.
Nothing is being Natted on the 1750 (even though there are nat statements on the inside and outside)
Here is the edited config
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key <hidden> address <hidden> no-xauth
no crypto isakmp ccm
ip access-list extended ATS-TRAFFIC-CA
permit ip 192.168.20.0 0.0.0.255 172.25.91.64 0.0.0.31
ip access-list extended ATS-TRAFFIC-DR
permit ip 192.168.20.0 0.0.0.255 172.29.91.64 0.0.0.31
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto map ACME 1 ipsec-isakmp
set peer <hidden>
set transform-set ESP-3DES-SHA
match address 101
crypto map ACME 2 ipsec-isakmp
set peer <hidden>
match address ATS-TRAFFIC-DR
crypto map IGOR_TW 3 ipsec-isakmp
set peer <hidden>
match address ATS-TRAFFIC-CA
interface FastEthernet0
ip address <outside address hidden>
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
crypto map IGOR_TW
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface Vlan1
ip address 192.168.20.1 255.255.255.0
so the first two tunnels work, but the third does not. I am out of ideas.
hi colin,
are the two peers able to ping each other's WAN/public IPs?
please provide sanitized config from your ASA for the 3rd VPN tunnel.
kindly do a LAN-to-LAN IP ping and post the debugs (from any peer), i.e. from 1750:
ping 172.25.91.65 source 192.168.20.1
debug crypto isakmp
debug crypto ipsec
14 Replies 14
rizwanr74
Level 7
Level 7
Hi Colin,
I see, you have two separate crypto instances have been created as shown in the red and green fronts.
set peer <hidden>
match address 101
set peer <hidden>
set peer <hidden>
Whereas I see only this particularity crypto instance is assigned to Interface "FastEthernet0"
ip nat outside
duplex auto
speed auto
crypto map IGOR_TW
Do you have different interface where other crypto instance is being terminated on?
sorry, that was a typo. the third entry is
crypto map ACME 3 ipsec-isakmp
set peer <hidden>
and the map on the interface is ACME
I was replacing the name IGOR_TW with ACME
Are you doing NAT exemption on the VPN traffic.
If so have you done it for the tunnel that isn't working ?
Jon
Actually, I just too the NAT out of the picture altogether (removed ip nat inside, and ip nat outside for the interfaces
this router only does VPN, so no need for the NAT
Still not working for the third tunnel. When I do a ping from the remote end, the tunnel comes up, but no traffic comes back. The debug says Phase 2 completed.
I cleared the session, re-entered the key, and checked ACLs on both sides.
Are you able to post the trouble tunnel configuration piece?
I am seeing some weird errors on the 1750 router side
ISAKMP:(0:112:HW:2):deleting node 2089010888 error FALSE reason "Informational (in) state 1
and
*Sep 26 15:09:54.479: ISAKMP:(0:112:HW:2):purging node
It is not easy to trouble shoot with log messages, log messages could means many things.
well I did some deep debugging, and the ASA successfully sets up the tunnel, with the correct encryption domains (I thought maybe it was an issue with the ACLs, but everything looks perfect in the debugs). The errors above were probably when I was clearing the session during troubleshooting.
Nevertheless, I can't ping through the tunnel. The other two tunnels don't have this issue. I've never seen this before.
hi colin,
debug crypto isakmp
debug crypto ipsec
hey John:
both devices can ping each other's WAN/outside interfaces.
I can get you the debugs in the morning.
This is very strange, as when the ASA detects the interesting traffic, it initiates tunnel setup, and according to what I saw in the logs, it completes (goes ACTIVE). I see packets getting encapsulated/encrypted outbound, but nothing is coming back.
It's like the return traffic is getting black-holed. Could the ISP be blocking ESP? (it is on a protected government network)
hi,
i would need the snippet of your ASA config and debug output to see what's really going on. i suspect the crypto ACL aren't matched or properly configured. i haven't seen ISP blocking VPN traffic although i've heard china ISPs have started to do so.
OK, this gets even stranger
After checking the ACLs and configs, I built two packet captures: one on the ASA, and one on the Router for icmp echo and echo-reply between hosts 172.25.91.67 and 192.168.20.20.
I see the traffic go through the ASA as the tunnel is set up without errors.
On the router, I see the tunnel come up and the icmp echo requests arrive and hit 192.168.20.20
The replies are sent back out through the tunnel by the router
But the packets are never received by the ASA -they are "lost in transit" somewhere. So return traffic vanishes.
Problem solved:
The ISP was blocking ESP (protocol 50), but was allowing 500 through. The tunnel would set up, but no traffic could go through it.
Ok, which instance of ACME instance you are having issue with, please post that configuration piece alone.
thanks.
