Split tunnel issue with ASA 5505 and 2621xm
weichiang
Hi all
I have an ASA5505 in NEM mode, connected to a 2621xm Easy VPN headend. I can get the NEM tunnel up, and there is full internal connectivity within the internal network (site A uses 10.1.0.0/16 and site B uses 10.2.0.0/16).
However, I can't seem to get split tunneling to work at site B where the ASA is, in spite of having the following config on the headend. Does anyone have any suggestions?
crypto isakmp client configuration group EasyVPN_NEM
key vpnkey
acl Split-Tunnel
ip access-list extended Split-Tunnel
permit ip 10.1.0.0 0.0.255.255 any
Thanks!
Dennis Leon
If the communication works fine over the VPN tunnel, you should check if you have NAT properly configured on the ASA side to reach de Internet.
Can u please post the ASA's config?
D.
Thanks for looking into this Dennis. Here is my ASA config. It was built by ASDM as I'm not familiar with configuring ASAs.
: Saved
ASA Version 8.4(1)
hostname ASA5505
domain-name domain.com
enable password xxx encrypted
passwd xxx encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 10.2.1.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 192.168.1.2 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
dns domain-lookup outside
dns server-group DefaultDNS
name-server 8.8.8.8
name-server 8.8.4.4
object network obj_any
subnet 0.0.0.0 0.0.0.0
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (inside,outside) dynamic interface
nat (inside,outside) after-auto source dynamic any interface
route outside 0.0.0.0 0.0.0.0 192.168.1.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
http server enable
http 10.0.0.0 255.0.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
telnet timeout 5
ssh 10.0.0.0 255.0.0.0 inside
ssh timeout 5
ssh version 2
console timeout 0
vpnclient server 2621xm-headend.domain.com
vpnclient mode network-extension-mode
vpnclient nem-st-autoconnect
vpnclient vpngroup EasyVPN_NEM password *****
vpnclient username ASA5505 password *****
vpnclient management tunnel 10.1.0.0 255.255.0.0
vpnclient enable
dhcpd auto_config outside
dhcpd address 10.2.1.101-10.2.1.132 inside
dhcpd dns 8.8.8.8 8.8.4.4 interface inside
dhcpd domain domain.com interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
username user password xxx encrypted privilege 15
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:ade5aa8ed68a82c37d092a9fdf04e590
: end
Well, the configuration looks fine to me...just to clarify...your problem is that you cannot reach the internet from the network behind the ASA? right?
That's right. I can reach the HQ site internal network just fine, though.
