05-03-2004 11:31 PM - edited 02-21-2020 01:08 PM
I'm not able to establish a vpn tunnel to a NCP vpn gateway.
I'm especially interested on the debug message: " ISAKMP: reserved not zero on payload 8!" - What does it mean?
Thank you in advance
M. König
Here is the debug output from my Pix 6.3.1:
(identity) local= ffmcif1_os, remote= lpk_os,
local_proxy= ffmz1_is/255.255.255.255/0/0 (type=1),
remote_proxy= lpk_ftp/255.255.255.255/0/0 (type=1)
ISAKMP (0): beginning Main Mode exchange
crypto_isakmp_process_block:src:lpk_os, dest:ffmcif1_os spt:500 dpt:500
OAK_MM exchange
ISAKMP (0): processing SA payload. message ID = 0
ISAKMP (0): Checking ISAKMP transform 1 against priority 5 policy
ISAKMP: encryption 3DES-CBC
ISAKMP: hash SHA
ISAKMP: default group 2
ISAKMP: auth pre-share
ISAKMP: life type in seconds
ISAKMP: life duration (VPI) of 0x0 0x1 0x51 0x80
ISAKMP (0): atts are acceptable. Next payload is 0
ISAKMP (0): processing vendor id payload
ISAKMP (0): received xauth v6 vendor id
ISAKMP (0): remote peer supports dead peer detection
ISAKMP (0): speaking to a Unity client
ISAKMP (0): SA is doing pre-shared key authentication using id type ID_IPV4_ADDR
return status is IKMP_NO_ERROR
OAK_MM exchange
ISAKMP (0): processing KE payload. message ID = 0
ISAKMP (0): processing NONCE payload. message ID = 0
ISAKMP (0): ID payload
next-payload : 8
type : 1
protocol : 17
port : 500
length : 8
ISAKMP (0): Total payload length: 12
ISAKMP (0): retransmitting phase 1...
ISAKMP (0): deleting SA: src ffmcif1_os, dst lpk_os
ISADB: reaper checking SA 0x3596154, conn_id = 0
ISADB: reaper checking SA 0x35a0a34, conn_id = 0
ISADB: reaper checking SA 0x3541534, conn_id = 0
ISADB: reaper checking SA 0x2d0e054, conn_id = 0
ISADB: reaper checking SA 0x2d07f44, conn_id = 0
ISADB: reaper checking SA 0x3599104, conn_id = 0
ISADB: reaper checking SA 0x353194c, conn_id = 0
ISADB: reaper checking SA 0x2d0721c, conn_id = 0
ISADB: reaper checking SA 0x359e734, conn_id = 0
ISADB: reaper checking SA 0x353cf64, conn_id = 0
ISADB: reaper checking SA 0x35a4424, conn_id = 0 DELETE IT!
VPN Peer:ISAKMP: Peer Info for lpk_os/500 not found - peers:17
05-10-2004 06:17 AM
The statement: ISAKMP: "reserved not zero on payload 8! " generally refers to a pre-shared key mismatch. Looks like you pre-shared key is not right. Try and unapply the crypto map and the isakmp of the interface, remove the preshared key, and re-enter it again, then reapply the crypto map and isakmp on the interface, clear the sa and then reinitiate the tunnel. This should work.
