VPN Tunnel between 1751v and pix501...strange problem?
jasonhumes
SO I'v setup many vpn tunnels between IOS routers and pix firewalls and never had this issue before. I've got basic configs on the pix which I've triple checked the details on to make sure they match the router and they do...yet I keep on getting the same error message from the router and the tunnel does not come up....
QMP1751#
QMP1751#ping
Protocol [ip]:
Target IP address: 192.168.63.101
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: 192.168.60.1
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Sending 5, 100-byte ICMP Echos to 192.168.63.101, timeout is 2 seconds:
Packet sent with a source address of 192.168.60.1
*Mar 1 03:49:14.283 UTC: IPSEC(sa_request): ,
(key eng. msg.) OUTBOUND local= 216.8.167.63, remote= xxx.202.68.241,
local_proxy= 192.168.60.0/255.255.255.0/0/0 (type=4),
remote_proxy= 192.168.63.0/255.255.255.0/0/0 (type=4),
protocol= ESP, transform= esp-3des esp-md5-hmac (Tunnel),
lifedur= 3600s and 4608000kb,
spi= 0x6549A67(106207847), conn_id= 0, keysize= 0, flags= 0x400A
*Mar 1 03:49:14.283 UTC: ISAKMP: received ke message (1/1)
*Mar 1 03:49:14.287 UTC: ISAKMP (0:0): SA request profile is (NULL)
*Mar 1 03:49:14.287 UTC: ISAKMP: local port 500, remote port 500
*Mar 1 03:49:14.287 UTC: ISAKMP: set new node 0 to QM_IDLE
*Mar 1 03:49:14.287 UTC: ISAKMP: insert sa successfully sa = 8209CFD8
*Mar 1 03:49:14.287 UTC: ISAKMP (0:1): Can not start Aggressive mode, trying Ma
in mode.
*Mar 1 03:49:14.287 UTC: ISAKMP: Looking for a matching key for xxx.202.68.241
in default : success
*Mar 1 03:49:14.287 UTC: ISAKMP (0:1): found peer pre-shared key matching xxx.2
02.68.241
*Mar 1 03:49:14.291 UTC: ISAKMP (0:1): constructed NAT-T vendor-07 ID
*Mar 1 03:49:14.291 UTC: ISAKMP (0:1): constructed NAT-T vendor-03 ID
*Mar 1 03:49:14.291 UTC: ISAKMP (0:1): constructed NAT-T vendor-02 ID
*Mar 1 03:49:14.291 UTC: ISAKMP (0:1): Input = IKE_MESG_FROM_IPSEC, IKE_SA_REQ_
MM
*Mar 1 03:49:14.291 UTC: ISAKMP (0:1): Old State = IKE_READY New State = IKE_I
_MM1
*Mar 1 03:49:14.291 UTC: ISAKMP (0:1): beginning Main Mode exchange
*Mar 1 03:49:14.291 UTC: ISAKMP (0:1): sending packet to xxx.202.68.241 my_port
500 peer_port 500 (I) MM_NO_STATE.....
Success rate is 0 percent (0/5)
QMP1751#
I never see it trying to exchange attributes or anything...I've also talked with the upstream ISP and they claim that they are NOT blocking anything...hrmmm...any ideas. I've got some complex nat on the router, but that should not impact the ipsec tunnel stuff. Anyone...thanks.
jason
thisisshanky
Level 11
Level 11
Can I take a look at your configs ??
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Here is the configs for the pix and router.
What do you think? Thanks again
Jason
Try this command:
no crypto ipsec nat-transparency udp-encaps
If you are running 12.3T, read the following:
http://www.cisco.com/en/US/partner/products/sw/iosswrel/ps1839/products_feature_guide09186a0080110bca.html
PL
