Cisco community Site showing as not secure
Blue_Bird
Today Cisco community site is strangly showing as Not Secure..anybody noticed....?
it's  perfectly working now...Please ignore this message..!
Blue_Bird
It's seems it's perfectly working now...! Please ignore this message..!!
you may be going through a proxy etc or a web gateway like cisco umbrella... click on that red icon where it says not secure and see what is the certificate shown and the subject/SAN, and also the certificate chain. That will give you a idea of why it is not trusted.
amojarra
Hello @Blue_Bird
Thanks for reaching out
I would say it is best to:
[1] check the site certificate and the issuer
[2] check your system date
[3] try with other internet provider (for example your phone data service)
most probably, there is a proxy server in your network, that is decrypting the traffic and your browser is not trusting it, may I ask if yu have this issue just for CiscoCommunity or other HTTPS sites are having the same issue?
Amirhossein Mojarrad
++++     If you find this answer helpful, please rate it as such    ++++
