Problem with Videos from cnbc.com
Hello all
For a few days, I have problems to watch videos from cnbc.com. I get no blockmessage from Ironport and it seems, that the video starts, but then a circle (that normaly shows that the video is loading) turns endless. I have a S170 with 7.1.3-021.
Thanks in Advance for any ideas
Christian
Christian Rahl
I would highly recommend opening a support case with Cisco Tac.  As this can be a difficult problem to troubleshoot over the forums.
Christian Rahl
Customer Support Engineer
Cisco Web Content Security Appliance
Cisco Technical Assistance Center RTP
Christian Rahl
Christian Rahl
I'll do so. Thank you Christian.
Chris Illsley
Level 3
Level 3
As an aside, video hosting sites relatively regularly change how they host.
If you tail a grep based on the source IP and then try you should hopefully see what is being blocked.
Chris
I got the same tip from Cisco tac. Thank you for your help.
