05-01-2025 04:54 AM
Is there a way to Auto Assign a group from Azure to have certain admin roles ie Full admin and/or Partner admin?
I see you can synchronise webex groups but they seem to only have templates for features and not admin roles and also seems for for Active Directory than Azure
...or do you just have to sync the accounts to Webex and then another admin has to manually go in and assigned thee required admin permissions?
Solved! Go to Solution.
05-12-2025 02:57 AM
Hey there,
At this time, there is no ability for you to assign admin roles in Webex via an Azure AD group. The only way to assign admin roles to users is manually via Control Hub. This has been requested quite a bit, you can provide your vote here on the Webex User Feedback portal.
05-12-2025 02:57 AM
Hey there,
