Cisco Directory Connector Integration with Active Directory
stevenle
We are looking to sync user accounts and user attributes between Active Directory and Control Hub. We've read through the deploy guide and installed / configured Cisco Directory connector. We have the proper permissions set up both in house and in Control hub. Within one of our OU's we created a security group that has all of our Webex users. But for some reason no matter what LDAP filter we put in we can't get it to recognize the users within the security group to sync. We have a TAC case open and they are having a tough time as well. Not sure why this is so difficult and frustrating.
In the object selection section of the Cisco Directory connector i have this filter applied. All this does during a dry run is add the group but not the users within the group. I want all the users in that example group to be synced. Any suggestions?
stevenle
Got this working. Posting on the forums always seem to help, so thanks!
Put this filter in the Users section within Object Selection and now all users in the exampleusers group show up to sync (&(sAMAccountName=*)(memberOf=cn=exampleusers,ou=golf,ou=teetime,ou=tomorrow,dc=some,dc=com))
In case anyone else runs into this issue.
12 Replies 12
r-sirica
Hello There,
I have same issue. Could you explain the syntax of the string?
What is it that you're looking for clarification with the string/values in @stevenle response?
Response Signature
The use of the filter object in the Groups part of your screenshot is not intended to be used as you understand it. It's use is for filtering what group(s) to bring into Control Hub, not the actual member(s) of the group(s). The use of these group(s) are then to use them for controlling license assignment in Control Hub.
Here is an example of how we use this in our Control Hub.
Response Signature
Hello Roger,
can you send a screenshot of the Filter settings?
Hi @joachim.koester
Here you go.
However as this is very specific to each system it's of not much value. This is an examples of how to form the LDAP filter, (name=<name of the group>). If you have multiple groups that you need wrap the whole thing in parentheses and add a | to make it an or statement as per the LDAP filter "language", (|(name=<name of the group 1>)(name=<name of the group 2>)). Adapt it to fit your specific needs.
Response Signature
Hello, thaks for the infomations.
But every entrys i tried have no responce on Groups.
Is there a Minimum Version of the Connector required? We have installed the 3.7.3000.64632 and the auto Upgrade to a newer Versin is not working. I tried different Security Groups that are defined in the AD, but there are no Groups Syncronised to Webex.
Sorry but I don't know if there is any dependency on specific version. The auto update never works for us either, so we just download the latest available anytime we'd want to update the DC. Try that and see if there is any difference.
Response Signature
Us as well and the work around for us is easy enough that we haven't raised a TAC on the issue.  Here is the notes we have on the upgrade process.....
If automatic upgrade fails, manually stop the "Cisco DirSync Service" Windows Service. Then re-run the upgrade
check which should start the upgrade process again. When the upgrade is done, the Cisco DirSync Service should be restarted (running) automatically.
This. I just stop the service manually and run the upgrade. Once it completes, a reboot is required. The Cisco DirSync Service starts up automatically after the boot. Worked like a charm for us.
Thanks for taking the time to explain. Really appreciate it.
Vaijanath Sonvane
Recently I was in the same boat as you but I was able to resolve this issue. Instead of Groups, select Object Type as Users and try below filter:
(memberOf=CN=Webex,DC=example,DC=com)
The RED portion you can get is by OU >> Right Click >> Properties. In my case I created OU as Webex.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
stevenle
