Control Hub Reports
eservcoll
In need of more reporting options. Ideally a way to create custom reports. Specifically around devices. Not WebEx, we don't use that, we use Teams CVI. We have 250+ Room Kits and SX series registered to Control Hub. Reporting for these devices is horrible, unless it's there and we are not able to locate. TMS had this, moved away because this was supposed to be easier and provide more options. Currently all we can see via the reports are the total hours used per device per given range.
In need of:
Date/time of every call (Teams/Zoom/WebEx) made by each device
Length of each call
Thank you.
josviz
Hello @eservcoll,
The currently available reports from Control Hub can be found here:
Reports for Your Cloud Collaboration Portfolio
https://help.webex.com/en-US/article/nmug598/Reports-for-Your-Cloud-Collaboration-Portfolio
Please rate if it's “Helpful”.
If this answered your question please click “Accept as Solution”.
