Create Claim Rules to Allow Authentication from Cisco Webex
This might not be the right forum to post this in, I try it anyway...I am trying to create SSO login for Webex teams/meetings using this guide;
https://help.webex.com/en-us/nyx7kubb/Cisco-Webex-Control-Hub-Single-Sign-On-Integration-with-Active-Directory-Federation-Services
c:[Type == "http://schemas.microsoft.com/ws/2008/06/identity/claims/windowsaccountname"] => issue(Type =
"http://schemas.xmlsoap.org/ws/2005/05/identity/claims/nameidentifier", Issuer = c.Issuer, OriginalIssuer = c.OriginalIssuer, Value = c.Value, ValueType = c.ValueType,
Properties["http://schemas.xmlsoap.org/ws/2005/05/identity/claimproperties/format"] = "urn:oasis:names:tc:SAML:2.0:nameid-format:transient", Properties
["http://schemas.xmlsoap.org/ws/2005/05/identity/claimproperties/namequalifier"] = "https://idbroker.webex.com/1f7532cc-8e26-42e3-97f5-1559026de417", Properties
["http://schemas.xmlsoap.org/ws/2005/05/identity/claimproperties/spnamequalifier"] = "<EntityDescriptor xmlns="urn:oasis:names:tc:SAML:2.0:metadata" entityID="https://idbroker.webex.com/1f7532cc-8e26-42e3-97f5-1559026de417">
Here are the error messages we are receiving creating the custom rule, properly some sort of syntax fault, but I cannot find out where. Is someone able to pinpoint the error?
mtabrez
Thanks, but I think it is more of a syntax error, more than common known general error which the SAML error codes refer to.
The correct team of experts to help you are available by raising a case at support.webex.com. That said, once your issue is resolved, we'd love to hear if there was a fix that would work for our extended community. Come on back and let us know how you resolved this. thanks for being an active member of our Webex Community.
