CS-KITPLUS-K9 supporting native TEAMS ROOM capability!
vishalbansal
Can someone help me with Cisco Rom Kit Plus system CS-KITPLUS-K9 that i bought in September 2022, can be upgrade to native MS Teams Room capability!
If yes, then what all i may need for this upgrade!
Best I VB
Jonathan Schulenberg
The RK+ does not meet Microsoft’s hardware requirements for MTRoA. It will not be certified; your only option is to replace it with a current generation endpoint if you need MTR. Alternatively you can use WebRTC, CVI (VIMT), or Synergy Sky.
The RK+ was introduced in April 2017.
