Hybrid Calendar and in-room booking setup
gfolens
Level 4
Level 4
When you activate In-room booking for a Workspace you receive the following warning: "You must add a scheduling account in Hybrid Calendar settings to allow in-room booking.".
I looked in the Hybrid Calendar settings but could not find where to add the scheduling account.
gfolens
Level 4
Level 4
Finally found it in the Integration settings at the bottom.
What type of account should be added here?
gfolens
Level 4
Level 4
Cisco should update the Hybrid Calendar documentation to include this information.
I found this, thanks your info.
But I find another issue.
How can I add more workspaces in "Scheduling Account"?
It seem just only one workspace, right?
gfolens
Level 4
Level 4
It is quite hidden and hard to find in Control Hub and it has been moved around a few times. Glad you found it eventually. You’ll need an account that can create bookings in your room accounts calendars.
Response Signature
