Dial Plan to FXO
rtarson
So I am trying to configure phone gateway we have at a location that is directly attached analog to a old paging system. Which activates on a #25. Right now in WebEx I have the gateway CUBE connected as trunk to WebEX with the DialCast 31110. I have created a voice translation rule in the gateway for 31110 to go to #25
voice translation-rule 202
rule 1 /^31110$/ /#25/
voice translation-profile TRANSLATE31110
translate called 202
I then created a Voip DialPeer as seen below
dial-peer voice 3 voip
description Paging-in-VOIP
translation-profile outgoing TRANSLATE31110
max-conn 250
answer-address 31110
session protocol sipv2
incoming uri request 200
voice-class codec 99
voice-class stun-usage 200
no voice-class sip localhost
dtmf-relay rtp-nte
srtp
no vad
Then I have a dial-peer pots that is set for destination-pattern #25
dial-peer voice 2 pots
port 0/1/1
no sip-register
I have played around with changing called-party, answer-address ect... This configuration I atleast got better feedback with a  No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1).
I'm a little rusty when it comes to configuring dial-peer expecially going to a FXO Pots line, the tips or suggestions would be greatly appreciated. I have also provided a bigger snippet of the error I recieved when I tried to dial the dialcast incase it helps.
Jun 10 14:49:24.423 EDT: //-1/FDA1F1EAA352/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x7FB9CDFDF8C8, Call Info(
   Calling Number=182136,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=31110(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=3, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=13427
Jun 10 14:49:24.423 EDT: //-1/FDA1F1EAA352/CCAPI/ccCheckClipClir:
   In: Calling Number=182136(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=182136(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Jun 10 14:49:24.423 EDT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jun 10 14:49:24.423 EDT: :cc_get_feature_vsa malloc success
Jun 10 14:49:24.423 EDT:  cc_get_feature_vsa count is 1
Jun 10 14:49:24.424 EDT: :FEATURE_VSA attributes are: feature_name:0,feature_time:140436022724940,feature_id:18
Jun 10 14:49:24.424 EDT: //13427/FDA1F1EAA352/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=182136(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=31110(TON=Unknown, NPI=Unknown))
Jun 10 14:49:24.424 EDT: //-1/FDA1F1EAA352/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x7FB9DC4B4BD0; count=1
Jun 10 14:49:24.424 EDT: //-1/FDA1F1EAA352/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x7FB9DC50A9A8
Jun 10 14:49:24.424 EDT: //13427/FDA1F1EAA352/CCAPI/cc_process_call_setup_ind:
   Event=0x7FB9CF419588
Jun 10 14:49:24.425 EDT: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 31110
Jun 10 14:49:24.425 EDT: //13427/FDA1F1EAA352/CCAPI/ccCallSetContext:
   Context=0x7FB9C761AD68
Jun 10 14:49:24.425 EDT: //13427/FDA1F1EAA352/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 13427 with tag 3 to app "_ManagedAppProcess_Default"
Jun 10 14:49:24.425 EDT: //-1/FDA1F1EAA352/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x7FB9DC4B4BD0; count=1
Jun 10 14:49:24.425 EDT: //13427/FDA1F1EAA352/CCAPI/ccCallProceeding:
Jun 10 14:49:24.425 EDT: //-1/FDA1F1EAA352/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=31110, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=31110
Jun 10 14:49:24.426 EDT: Match Rule=DP_MATCH_DEST_SIP_USER; Called Number=31110
Jun 10 14:49:24.426 EDT: //-1/FDA1F1EAA352/DPM/dpMatchPeersCore:
Jun 10 14:49:24.426 EDT: //-1/FDA1F1EAA352/DPM/dpMatchSafModulePlugin:
   dialstring=31110, saf_enabled=0, saf_dndb_lookup=1, dp_result=-1
Jun 10 14:49:24.426 EDT: //-1/FDA1F1EAA352/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
@rtarson I would suggest running 'debug voice dialpeer' to see if the voice translation rule/profile is doing what you are expecting it to do. Let us know what you find and we can take a look.
I'd also like to see all of your dial-peers to see if there are any others interfering. When you post your config and your debug, please put the output in a text file and attach the text file to your post. Trying to read configs and debugs in the 'post window' can make it very difficult to parse.
Maren
Mikeevans
Have you figured it out? having kind of the same issue.
regards, mybakersfieldrealtor
So this is what I have:
We use a Dukan system which the paging activates on *2. Now this may not be needed because webex now has tranlation in webex
rule 1 /^71114$/ /*2/
voice translation-profile TRANSLATE_OLDPOTS
translation-profile outgoing TRANSLATE_OLDPOTS
destination-pattern 71114
port 0/1/1
no sip-register
description Paging System
max-conn 250
answer-address 71114
incoming called-number 71114
dtmf-relay rtp-nte
srtp
no vad
!port where you analog system is attached
voice-port 0/1/1
caller-id enable
Yes I will send over my configuration template in a few.
