How change Cisco Webex Room Kit Name ?
Yves.Derlet
I want to change the Cisco Webex Room Kit name.
How is it possible ?
I checked in the admin portal and I don't find it.
I try also to connect on the Room Kit but what is the login Password ?
Thank you
b.winter
If it's a Webex Cloud registered endpoint, then everything is done in Control Hub.
7 Replies 7
If it is a CM registered endpoint it is done under Product Specific Configuration Layout > System Unit > General Settings > Name.
Response Signature
b.winter
yes, it is on Cloud... but I find the solution.... It is not the device that I should rename, but the room.
It is ok.
Thank you
How to change the device name if it regsitred with Control hub?
You do that from the Workspace that the devices is associated with.
Response Signature
Thanks Roger.
You’re welcome! Please use the helpful vote if you found it useful.
Response Signature
