How to get a list of people in a group teamspace?
jwahlton
I created a Teamspace and need to get a report of all of the people in there to compare to an excel list.  How can I do that?
3 Accepted Solutions
Stephanie Knoop
Hi, @jwahlton . You can export space membership using this app:  https://power-pack.io. You can only export members for spaces in which you are also a moderator (or spaces that are unmoderated in which you are also a member).
There is not a built in report in the admin tool to do such a thing.
Response Signature
I ran a test myself prior to answering the post and found that I can obtain members for both unmoderated spaces where I was a member as well as moderated spaces where I am a member.
Response Signature
You may also utilite the Webex Rest API for listing all members of a space: https://developer.webex.com/docs/api/v1/memberships/list-memberships
By that, you can also do the comparison automatically if you need to do it regulary.
Power Pack is utilizing the Rest API as well internally.
6 Replies 6
jwahlton
Thanks  I was able to successfully export the list.
Stephanie Knoop
Response Signature
Thank you so much!
Hi @jwahlton,
Please note that using this tool you can export list of space members only if the space is moderated and you are the moderator.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Response Signature
