how to send a file to myself on webex
qjwang
Hi Webex experts,
I'd like to send one file on my phone to my laptop. I have webex on both devices, can I send it over webex? Thanks
lgomezro
hi
You can create your own space, you will be the only participant. In this way you can send to you notes and files and the information will be available into the cloud.
Go to the top of the messaging on Webex app, create a space, add a name, immediately you will be able to send files
Cheers
Luis
Jonathan Schulenberg
The product is not intended for this use case; it’s not Box, OneDrive, AirDrop, etc. Storage also has a cost above the included limits of your subscription, so don’t socialize the workaround below with your users.
You can trick the product into allowing this by creating a space with at least one other person and then removing them from it, leaving a space with only you in it.
