Issue to setup webex Micrsosfot Azure Active Directory Wizard app
kelvinteh15
Issue to setup webex Micrsosfot Azure Active Directory Wizard app . Getting the error "User role doesn't have sufficient privilege." As per the documentation https://help.webex.com/en-us/article/heauzeb/Set-up-Azure-AD-Wizard-App-in-Control-Hub#_9c79a158-ee26-4fc6-a986-87389351a4e5  . I have Azure admin to create the previlege in the Azure as per the attached file, could you advise if you know any role is missing that cause this ? Beside this , i also turn off the MFA for the service account .
Thanks.
kelvinteh15
Just to let you guy know . It required to give global admin for the service account. Delete the old cisco webex identity and redo the set up will do.
gpbox60
I had the same issue when I edited my data on alight motion mod apk after putting again all things were well.
kelvinteh15
kelvinteh15
This is page that when trying to sign in .
