Monitoring Webex Local Recordings
Mike_fbr
As an administrator, It is possible to known if a user do a Webex Local Recording? (in his own PC, not cloud recording)
Andres Salgado
Hi Mike,
Have you tried generating a recording report: Analytics>>Classic View>> then under Common Reports>>Recording Usage
Not sure if the last column of file type would be different for Cloud or Local recording
Alternatively, you can disable local recording on common settings by unchecking "Enable local recording for Webex (includes Meetings, Events, and Teams)"
Andres
Response Signature
Hello @Andres Salgado, thank you for your answer.
The reports generated under "Recording Usage" only show Network Recordings (cloud) info, but none of Local Recordings. Is a very important feature for control purposes and should be available somewhere or CISCO should consider adding this visibility urgently.
Hi Mike,
I couldn't find the feature under submitted ideas, you can add this feature to https://ciscocollabcustomer.ideas.aha.io/ and the respective team will evaluate for future releases.
Andres
Response Signature
