Bookmark
Subscribe
840
MS Azure integration with multiple WebEx Control Hub
asherif82
Hello All,
We have a customer who has a WebEx control hub already integrated with MS Azure. He purchased a new subscription to a new control hub. Is it possible to do integration with two different Control hubs with the same MS Azure? Also, by integrating the new WebEx control hub with Azure AD, would this lead to any issues for the existing users that are already in the current existing WebEx control hub?
Vaijanath Sonvane
If you have existing Webex Control Hub, then you can add new subscription to it.
As per below guides, I don't think you can add Cisco Webex application more than once in Azure AD. And also, I don't think you can provision multiple Webex organizations in same Azure AD.
https://docs.microsoft.com/en-us/azure/active-directory/saas-apps/cisco-webex-provisioning-tutorial
https://help.webex.com/en-us/aumpbz/Synchronize-Azure-Active-Directory-Users-into-Cisco-Webex-Control-Hub
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
