Showing results forĀ
Search instead forĀ
Did you mean:Ā
POST MEETING ANALYTICS
cpeebles_hms
In Control Hub, is there a way to produce user friendly analytics allowing meeting hosts the ability to review clear cut data of the meeting?  Currently, all I see available are Excel spreadsheets.
Vaijanath Sonvane
Hi @cpeebles_hms,
All the reports that you can generate in Webex Control Hub are in .CSV format. You can generate Webex Control Hub Analytics summary graphs in .PNG, .PDF or .CSV format but your can not generate it at individual host level. Cisco is continuously working on improving the Analytics Platform and hopefully they will come up with solution.
Also, as a host, the user can login to webex site and view your meeting insights. The meeting insights include average meeting length, number of participants, number of meetings, and more. Please see below article for more detials:
https://help.webex.com/en-US/article/nrvpkd0/View-Your-Webex-Meetings-Insights
If you think that, the detailed analytics per host/meeting needs to under Control Hub and needs to be in graphical format, then you can open enhancement request under below URL:
https://community.cisco.com/t5/collaboration-ccp-product/idb-p/4595j-ideas-collab-ccp
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
