08-13-2020 09:16 AM
We are wondering what the implications of converting to SSO Webex will have on preexisting users?
Solved! Go to Solution.
08-13-2020 04:53 PM
Hi there
I dont think so. The users should be able to get all their pre-booked meetings as the login is not changing. If you see in the webex site admin, the user email will be the users account name. All you do is use a single, common set of credentials for Webex applications in your organization.
https://help.webex.com/en-us/lfu88u/Single-Sign-On-Integration-in-Cisco-Webex-Control-Hub
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
08-13-2020 09:59 AM
08-13-2020 04:53 PM
Hi there
Hope this Helps
Cheers
Rath!
