Titles or badges
JNieves
Hello, I manage a team and we use Webex heavily to give recognition for accomplishments.  Can we get the ability assign a badge or existing emote to a webex member.  The idea behind it is that a few who have hit special benchmarks can see the badge attached to the name in chat and feel a sense of accomplishment.  The badge can be managed by moderators meaning they assign it to the member and possibly even customize it by importing an image like we do currently when you "edit a space setting"
Thank you!
Try different browser. Both  are working links.
Response Signature
JNieves
Hello, thank you for the helpful suggestions.  I tried both links provided and I do not have access.
"SAML login unsuccessful. This usually means the Identity Provider is not configured or the SAML user does not have permission for the application. No value found for SAML_SUBJECT when building the assertion from name/value pairs: {SAML_AUTHN_CTX=urn:oasis:names:tc:SAML:2.0:ac:classes:unspecified, SAML_NAME_FORMAT=urn:oasis:names:tc:SAML:1.1:nameid-format:unspecified}"
Response Signature
You can also use below link to submit your ideas.
https://ciscocollabcustomer.ideas.aha.io
Response Signature
Stephanie Knoop
Good evening. The portal to submit ideas for product management is located at the following link.
https://ciscocollaboration.ideas.aha.io/portal_session/new
Response Signature
