Upgrade from 2.8 to 4.0 Requirements
tsiemons
in the Uprade Path is one requiremnt that the Software at the System will be 2.8MR1 Patch 2 or later.
I cant found what is 2.8.1.3084.B-AE that is installed in my System.
At Cisco support software download only other Releases are to download.
Can somebody help me with translate the Number to the Patch Level
regards Thomas
Vaijanath Sonvane
Please see below information:
CWMS Release 2.8 - Build 2.8.1.17
CWMS Release 2.8MR1 - Build 2.8.1.1023
CWMS Release 2.8MR2 - Build 2.8.1.2039
CWMS Release 2.8MR3 Patch 4- Build 2.8.1.3118
  • Audio Encrypted -AE
  • Audio Unencrypted -AU
All MR3 release starts with 2.8.1.3XXX.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Vaijanath Sonvane
