Hi all,
I have a problem installing the Monitornig webex agent.
On vmware 6.7 I created a vm with windows server 2016, I met all the requirements indicated by cisco ... the problem is that the agent does not find an audio driver. In the virtual machine I have enabled the audio and in fact I hear the sounds from remote desktop ...I also edited the vmx file by entering:
sound.present = “true”
sound.allowGuestConnectionControl = “false”
sound.virtualDev = “hdaudio”
sound.fileName = “-1”
sound.autodetect = “true”
can anyone help me?
