Webex as Identity Provider for SSO
Hi all,
We are working on a Single Sign-On solution for our web portal. We managed to implement it using ADFS, Azure, Okta, and OneLogin as an identity providers.
What interests me is whether there is a possibility of using Webex as an identity provider and if the answer is yes, is there any documentation for that because I was unable to find it?
Thanks and BR
dtibbe
Recently, "Login with Webex" functionality was added to the REST Api: https://developer.webex.com/blog/implementing-login-with-webex
So at least in your own apps, you may implement something like SSO..
AFAIK it is not possible to use Webex as an IdP and that is likely why you do not find any information on the topic.
Response Signature
