Webex Edge Audio Configuration
saleem pc
Level 3
Level 3
We have Existing Webex Cloud site. it is managed by site admin. We are trying to configure WebEx Edge Audio so on prem CUCM registred IP Phone can be used for audio over Expresssway pair.
I am following the document
https://help.webex.com/en-us/xmsy7d/Cisco-Webex-Edge-Audio-Customer-Configuration-Guide#id_77131
As per document fist step is to get
Obtain dial-in numbers and Lua script.
 and first step for the same is
Collect Dial-in Numbers and Lua Script from Webex Site Administration
Sign in to Webex Site Administration and go to Configuration > Common Site Settings > Edge Audio Settings.
 However on my site admin page there is no option for "Edge Audio Settings" under Common Site Settings
Attached is the screenshot
Any help is appreciated.
mtabrez
Hi, have you already taken a look at https://help.webex.com/en-us/xmsy7d/Cisco-Webex-Edge-Audio-Customer-Configuration-Guide, the guide comprehensively covers all steps to configure Webex Edge Audio.
Configuration guide to set up your Edge Audio solution. You will need access to Webex Site Administration, Cisco Unified Communications Manager, Expressway-C configuration, and Expressway-E configuration
This is the same document I mentioned in my post, the challenge I am facing is the first step itself dont exist in Site Admin page, or in control hub. I already shared the screenshot. Does this require any additional license along with webex cloud meeting license ?
Step1
Please contact sales to verify if Webex Edge Audio has been enabled for your Webex Site
