04-28-2020 07:12 AM
When I use zoom, there is one option that allows me to set up breakout rooms. I am wondering how could I do that in Webex meetings? Does Starter version of Webex meeting have this feature?
Thanks.
Solved! Go to Solution.
06-17-2020 03:08 PM
Breakout rooms have not yet been added to Webex Meetings. This should be available later this year. others have also been using webex Teams for breakouts in the meantime.
@tomliuwhite wrote:When I use zoom, there is one option that allows me to set up breakout rooms. I am wondering how could I do that in Webex meetings? Does Starter version of Webex meeting have this feature?
Thanks.
06-17-2020 03:08 PM
Thanks.
06-17-2020 03:14 PM
You also have the ability to use breakout rooms in Webex Training but you would have to check with your admin to see if you have that licensing. Webex Training also has other "classroom" type features such as tests and labs.
06-17-2020 03:04 PM
were you able to find a solution to use breakout rooms in a WebEx meeting?
