07-22-2020 01:20 PM
We have terminated employees in Team and inactivated them in the admin portal. They still appear when you do a name search. Is there a way to remove them so they can't be selected?
07-23-2020 04:42 AM
07-23-2020 05:23 AM
So once member is marked as disabled in AD the directory connector should be removing them from the Control Hub? We shouldn't be manually removing them from Control Hub? Sorry just trying to understand the process to ensure we are doing this correctly. Thanks.
07-24-2020 04:49 AM
07-24-2020 05:13 AM
Thank you very much appreciate the assistance.
07-22-2020 06:16 PM
Alicia,
Remove them from AD and see if that makes any difference.
UA-huddle Team
07-23-2020 04:59 AM
Terminated member is in the disabled ou in AD. But still shows as a selection when I am in Webex Teams. So if I delete them from AD instead of in the terminated OU it should work?
