Can the Samsung Flip be used as the primary touch panel and replace the need for the Navigator panel?
What is the purpose of Avatar in Cisco Directory connector config?Is that mandatory to configure while configuring Directory connector with WebEx control Hub?
What time of day will the updates happen? I'm unable to find this information any where. I know our specific date, but I do not know the time. Thank you!
I did not setup single sign on for WebEx, this was done by someone who is no longer with our company.I see in the admin portal that my Cisco (SP) cert is expiring soon, but the cert usage shows "none". We use Azure IdP which is valid for another few ...
Does anyone have a macro to keep the Cisco Spark Units / SX80 in Halwake mode and not to go in to standby ? I have seen several Macros to keep it from shutting down and to keep in out of halfwake mode but not to keep it in.. const xapi = require('xa...
Can SubTitles be in Vietnamese language?
I want to change the meeting scheduler in Cisco Webex to default to MS outlook and not Webex Scheduler for all of my users. Is there a setting in Hub that will change this for all of our associates using Webex?
Previously users were able to type in @webex in outlook for the meeting location and that populated WebEx meeting information in to the body of the meeting invite, this has stopped working in the past 2 days and we are receiving a lot of calls from E...
Has anyone here got the Webex Monitoring Service Agent to install successfully? We followed the very sparse documentation that they have here for it to the T, and we still get the error "We did not detect a valid audio driver on the machine" during i...
Hi all,I have a problem installing the Monitornig webex agent.On vmware 6.7 I created a vm with windows server 2016, I met all the requirements indicated by cisco ... the problem is that the agent does not find an audio driver. In the virtual machine...
Good Day everyone, since we deplay webex in our VDI we try to figure out how we can manage the Versionsupdates from the VDI Plugin and the VDI Webex App. normaly we would say, that we install a version, like 42.2.0.... on our Citrix Server and if we ...
Hi Expert In webex event --> Schedule an Event --> event typeHow can we enable online event + video session in control hub?I only can see online event in even type.I am admin for webex
Hello,I have 40 Meeting Rooms with Webex Roomkits (Plus, Mini, Normal) where an Airmedia AM-200 is connected for sharing purposes. After adding these Roomkits in Control Hub (Webex Edge for Devices) , the software of the room gets automatically upgra...
Hello,We just bought a brand new Cisco Webex Room 55 and I was trying to connect it to the Touch 10 device that comes with it, but I am getting an error stating that the device is not supported or needs to be updated. This is on an isolated network w...
We have several conference rooms with Room Kit Mini and Flip 2 65" screen. I now need to upgrade a room with an 85" screen. I can't find any docs detailing compatibility for the 85" Samsung Flip models. There are 3: Flip 2 WM85R (which I assume works...
| Subject | Author | Posted |
| 09-11-2026 10:32 AM | ||
| 07-30-2026 08:19 AM | ||
| 06-30-2026 01:07 AM | ||
| 05-22-2026 10:27 AM | ||
| 05-12-2026 11:28 AM |
