dial plan in webex calling
rmanakadav
Level 2
Level 2
Hi All,
checking if there is a way to achieve below scenario from webex control hub
1. Agent call customer  number with a prefix eg: 8764<customer number>
2. call will route to a specific destination while dialling above format
3. before routing need to strip off the prefix 8764
can some one help me in this above configuration from webex control hub
Vaijanath Sonvane
Hi @rmanakadav,
You can achieve this by using Translation Patterns. The configuration can be done in control hub under Calling >> Call Routing >> Translation Pattern.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
