Difference between Wbx Calling Multi Platform & Wbx DI
solihul.hadi9
Hi All,
Can you share articles or you can explain so, what a difference about Webex Calling Multi Platform and Webex Calling Dedicated Instance . I need table comparison (pros and cons)
Respectfully,
SH
dtibbe
Webex Calling MT/MP is basically the known cloud-based calling platform. It has its roots in Broadsofts  cloud calling solution. It is a great cloud calling solution offereng a rich feature set that will be fine for most users.
Webex Calling DI is basically a UCM hosted by Cisco and you're the only user of that instance. So the feature set is much more sophisticated than for WxC MT
