Showing results forĀ
Search instead forĀ
Did you mean:Ā
Enable Webex greetings and disable webex voicemail
enricos
Hello Everyone,
I just want to know if it is possible to have the webex greetings enabled while the voicemail is disabled. From what I understand the greeting settings is only enabled when the voicemail is also enabled.
Looking forward to any response.
Enrico
keclair
You can accomplish this by using the Extended Away Greeting. Here is how to activate that feature
https://help.webex.com/en-us/article/2kowmab/Set-Up-and-Manage-Your-Extended-Away-Greeting
Thanks a lot @keclair
