iPhone not ringing if the application is not open
irvin.navarro
If the Webex application is no directly opened, the phone will not ring and will only ping a miss call. Only rings when the application is opened on the home screen.
tried re installing the application but the problem comes back shortly after.
Any fixes?
Thanks!
10 Replies 10
ScottFugate0883
Any answers yet?
ken-patel
Did you find any solution?
I am having the same problem now
Cucm version needs to be above a certain level. Sorry I don’t have the info infront of me.
APN setup is just required when using UCM.
As we're in the Webex Calling forum, I think @irvin.navarro is referring to Webex Calling (Cloud Calling), right? In that case, no APN setup is required..
Hi @dtibbe ,
you are correct.
thanks,
Irvin
StaceyPurdy
Have you checked to make sure the "Background app refresh" setting is enabled? iPhone Settings - Webex - toggle the setting on.
Yes background app refresh is enabled.
Did you find a fix?
Unfortunately not yet. Webex did put out new version of the application but that didn't solve the issue.
