08-06-2024 08:27 AM
I need to integrate a 3rd party SIP device for an especific IVR Solution. I will need to use port 5060 unecrypted.
Is this supported by Webex?
Solved! Go to Solution.
08-06-2024 08:33 AM
No, in order to use Webex Calling, SIP over TLS is required, along with SRTP. The recommendation would be to place a Cisco CUBE (or other supported SBC) as a Local Gateway which can connect to the 3rd-party device on one side and Webex Calling on the other.
08-06-2024 08:33 AM
