Multiple CPP on same location
victor_angeles
Level 2
Level 2
Anybody knows if there's any way to have two or more CPP on the same location for redundancy of least cost routing?
Thank you.
Victor
dtibbe
Each location can just have one PSTN connectivity. If you have a LGW in place, you may trick around and do the magic there..
You may also have a look at https://help.webex.com/n0xb944/
