Showing results forĀ
Search instead forĀ
Did you mean:Ā
SIP/2.0 488 Not Acceptable Media
aniket0422
Hello Guys,
Facing Issue with WebEx Calling.
Inbound calls are reaching to the WebEx user but going directly to the missed call tab. User is not getting any ring and not able to answer calls.
In LGW debug we are getting SIP/2.0 488 Not Acceptable Media
Attached are the debugs from LGW. Can someone suggest what I am missing here.
Call Flow - PSTN User - SIP Provider - LGW - WebEx Cloud - WebEx User.
dtibbe
You should wipe out your credentials from the configuration file and quickly generate a new password for the LGW!
