Use CUBE licenses for Webex calling in PSTN trunk
joelcontreras1
Hello.
I hope everyone is well. I'm in the process of migrating from CUCM to Webex Calling. My client has 5 CUBE 4331, and I've already asked them to purchase the SEC license and upgrade to 17.12.2 or higher. Additionally, my client on that same gateways wants a SIP trunk to the PSTN, and here's my question. Cisco provides me, CUBE licenses, when I purchase Webex Calling licenses. I buy 1,000 and I get 250 CUBE licenses. (I think it's for 125 simultaneous calls.) Can I set up a SIP trunk to the PSTN and take advantage of these licenses? (The question doesn't sound right, but that's basically it.)
Matt_W
Level 3
Level 3
If you are using the local gateway licensing with A-Flex-3 then those are provided at 1/2 the number of Professional Webex Calling Users on the subscription (as long as local gateway is selected).  Additional CUBE licenses are purchased separately. There are some processing and connection limits based on the ISR you are using.  It is best to discuss your licensing needs with a Cisco reseller to best come up with a solution based on your deployment.
https://www.ciscopress.com/articles/article.asp?p=3188200&seqNum=4#:~:text=A%20connection%20is%20configured%20to,Gateway%20based%20on%20registration%20type.
Sizing by Concurrent Calls per Local Gateway
Sizing by Number of Users Behind a Local Gateway
Trunk Type Preferred
Minimum Link Quality
~ 2000–6500
65,000
Certificate-based
Interconnect
250–~2000
20,000
Certificate-based
Over the Internet
Up to 250
2500
Registration-based
Over the Internet
Matt_W
Level 3
Level 3
~ 2000–6500
65,000
Certificate-based
Interconnect
250–~2000
20,000
Certificate-based
Over the Internet
Up to 250
2500
Registration-based
Over the Internet
