Voice Portal admin
Tommy2143
Visitor
The end user tried logging into the voice portal to record a greeting for the auto attendant, however they got locked out. I've reset the portal pin but it doesn't seem to unlock the login. What am I missing with this?
bstudebaker
Level 3
Level 3
we have this same issue....seems like there is some kind of timer that when you reset the pin in CH it will lock back out after x amount of time....its a pain in the ass
Yes, all settings have been configured, but it still just says locked out, even after I reset the pin
Did you ever get a resolution for this ?
