Voicemail
lbednarz
How can i send my voicemail  to another person?
alejandro1987
Hello @lbednarz
If you have Cisco Unity Connection ...
Also, if these actions need to be done many times, you can try with alternative extensions, depending on the type of scenario, for example, you can set up an alternative device in Unity Connection, callers can listen and leave messages, and the alternative extension can review them.
In my case, one person needed to listen and take note of another's mailboxes, therefore the solution was functional since it was not necessary to always forward the mailboxes.
dtibbe
Check this help article: https://help.webex.com/nim1pc/
When listening to your voicemail, press 9 for additonal options, then 2 for forwarding the message.
