Third party softphones in Webex Calling?
dgonzalez1
Hello, I wanted to know if someone had the chance to make third party softphones (as for example MicroSip) register to Webex Calling. Is that possible?
Diego.
dtibbe
There is a list of supported devices available at https://help.webex.com/qkwt4j/.
Yours are not listed there. You may try grabbing the sip credentials from an Grandstream doorbell for instance and try if you can get your system work -- it will not officially be supported.
Yes, I went through that list, but there is no softphones listed there.
I know it wouldn't have any support, but just wandering if it could work.
Thanks.
