09-28-2023 10:03 AM
09-28-2023 10:11 AM
https://help.webex.com/en-us/article/ns2bgr/Create-and-manage-call-queue
make sure that you have the setting referred to in section 3
Allow queue phone number for outgoing calls—Enable the toggle to allow the queue phone number for outgoing calls.
then in the Webex App, you will need to check the name of the Call Queue.
This should allow your users to call out with the Queue Telephone number
09-28-2023 12:09 PM
If each queue is only assigned an extension will this still work or do I need to assign a number for each queue?
09-28-2023 01:22 PM
Typically a Call Queue is assigned a TN so that it can be reached by callers this would allow your agents to select that number when making outbound calls.
Are calls reaching your Call Queues in a different manner? ex Auto Attendant and option 1 goes to a Queue , Option 2 goes to another Queue
10-02-2023 12:30 PM
Yes we have two auto attendants that flow the calls into the queue's. I have the dial out number as the auto attendant, but it still shows as the main corporate office number even though each auto attendant is a different number.
